Question about Ricoh A3 Gel GX7000 InkJet Printer
I just purchased the Ricoh GX7000 for sublimation. Unfortunately, my son set up the printer and did not realize the inks that come with it are not to be installed. He did. I have not printed anything, but everywhere I read it says not to install the original inks. How do I proceed? Do i just install the sub inks, or purge what is in the lines?
I would call your vendor. Or if you bought the sawgrass technologies ink, give tech support a call and have them help you download the necessary ICC profile for your printer. Often they can walk you through setup. You will need to delete the current one you son installed.
Narri
Posted on Nov 09, 2010
How use epson l800 for sublimation ink
Hi.
There are things that you need to understand when using third party inks on CISS Ready Printers. Epson L800 is built to use inks manufactured by Epson and therefore using other inks than specified will automatically void the manufacturer's warranty on the device.
Sublimation Inks are heat sensitive inks but it can be used to most of the Epson Printers on the market. If your L800 is already running using Dye Inks now, you may need to "flush" the Tanks, Tubes and Print Nozzles to avoid ink clogging. Mixing different types of ink is the most common mistake resulting to printhead clogging and by not flushing, you may as well encounter this. If you can buy a new CISS Tanks and cartridges fitted to L800, you may also want to do so to make flushing easier. You only need to flush the nozzles if you replace the CISS Kit.
Flush using a Syringe with the tube on the part where the needle is supposed to be placed. To flush the nozzle, press the "ink" button on the printer. As the cartridges move to the center, pull the power plug to shut down the device. Remove all the cartridges to expose the nozzles. Move the cartridge holder a to the right enough not to lock it in its terminal. Put a paper towel in the base of the printer and move back the cartridge holder placing it on top of the paper towel.
Fill your syringe with cleaning solution and securely attach the other end of the tube to the nozzle. MAKE SURE YOU DO NOT SPILL cleaning solution to any circuitry in the cartridge holder. Squeeze the syringe slowly to flush out the remaining inks on the printhead. 3 to 5 ml would do the flushing. Repeat the flushing to all of the nozzles. Again, be careful with the circuits.
After flushing, remove the paper towel and clean up the base of the printer.
Load your new (or flushed) CISS Kit into position.
After installation, it is necessary to conduct initial setup to rerun the ink from Tanks to tubes to cartridges and to printhead. After initial setup, a nozzle check and cleaning would also refine the quality of the print.
If you ever encounter ink-clogging on your nozzles again, the flushing will also help you do the trick unless your printhead already ran out.
I hope this helps.
Chow!
Apr 23, 2014 | Ricoh A3 Gel GX7000 InkJet Printer
Ricoh gx7000 error code 993
This signal is triggered by the HVPS due to an accumulation of
condensation or ink spillage onto the transport belt.
?? Clean the transport belt.
Feb 28, 2014 | Ricoh Corp Aficio GX7000 GelSprinter Print...
I have a ricoh gx 7000 used for sublimation. Everytime I turn it on, I get a "paper misfeed" message. HELP!!
Dear .
Paper miss feed error indicates to :
1- Piece of paper inside duplexer unit check out from the back side..
2- magnetic strip (encoding tape on the top of linear steel bar) is dirty or it has some ink spots
use alcohol & cotton pass along the strip from the 2 side.
Note turn your machine off and un-plug the power
To clean behinde the head area you should first turn the machine on, when the head move to the left side unplug the power cable
I hope it may help
Yasir Risay
Aug 20, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
How do i reset the counter when i have replaced a ink collector unit on my richo gx7000.
Push the menu key.
Push enter key three times.
Turn printer off then on
See my video at www.condetv.com
Search for waste ink.
Mar 13, 2011 | Ricoh Aficio GX3050 GelSprinter
I have an epson r 230 printer i have a problem that i cannot get its inks i have a ccs system fitted i am using a fine tone sublimation inks
HI, you can use any sublimation ink suitable for epson desktop printers. The sublimation ink is not specifid for model, it's work on every epson destok printers
Mar 08, 2011 | Epson STYLUS R230 InkJet Photo Printer
Ricoh Gx7000 inkjet A3 Printer - what does 'error 990' mean?
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
Feb 13, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
I have a Ricoh GX7000 Gel printer. I have diagnosed that the main board is faulty. How can I get a replacement circuit board for my printer... anyone with any useful info?
If it's the entire board I don't really know. You might be better off getting a new printer If it's a chip you might try here...Good luck
http://www.aliexpress.com/wholesale/wholesale-ricoh-oem.html
Oct 18, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
Power Outage
Unfort don't have a solution but curious as to the ink you were using. Were you using OEM inks or dye sublimation ink from like Sawgrass ?
Jul 27, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
Add sublimation ink to cartridge for epson c88
The CISS are auto resetebale? If not, you must get a CISS with an autoreset button to get the printer work with the CISS
Oct 06, 2009 | Epson Stylus C88 InkJet Photo Printer
Ricoh A3 Gel GX7000 InkJet Printer Logo
440 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
