Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Getting gas getting spark. was working fine I shut it off to load wood. When I tried to start it back up it wouldn't. Cleaned spark plug and air filter started but as soon as I gave it gas it shuts off
  • 297 Answers
Did you add fuel before you tried to restart? is it the correct/same fuel you were using before?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 04, 2010
I can ususally get my chainsaw to start fairly easily runs fine for about 3/4 a tank of gas then abruptly shuts down
I'd try a basic maintenance and then see what happens.
- Change spark plug
- Pull fuel filter. Clean or replace.
- Remove air filter, clean or replace.
- Remove muffler. Clean all carbon from spark arrestor screen.
Start and set carb fast, slow, and idle. If you want coaching on the procedure, reply as a COMMENT to this post.
Cheers.
Apr 15, 2016 | Garden
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Won't start,charged oil,cleaned spark plug and air filter.has gas.
If your tiller has sat for any length of time it may have stale gas and the spark plug may need replacing (not just cleaning). Always make sure all wiring and or connections are clean. You can check for spark by removing spark plug, insert it back into spark plug wiring, using a WOOD clothes pin to hold the wire, hold spark end of spark plug (holding the clothes pin only) on metal casing on machine, pull starter cord and check for spark. If you don't use a non conductive instrument such as the clothes pin you will get a nasty shock. If you have no spark it is time to change the plug. Always put your safety first! Hope this helps! Have a great day! If this doesn't work perhaps you will need more information.
Mar 30, 2015 | Troy-Bilt Pony Garden Tiller
Robin Subaru EX40 engine will only run at idle. Increasing the throttle causes it to stall.
Try blowing your gas line out.. sounds like your getting gas but not enough
Oct 13, 2014 | Motorcycles
How do i stop the back firing and get it started
I had possibly the same problem with my lawn tractor about a month ago... I tried removing the carburetor and cleaning it, but I always ended up pushing debris into another area and creating new problems. Eventually I just bought a new carburetor, changed the oil (some gas had gotten into my oil thanks to the problems I had with my carburetor), cleaned the spark plug, emptied the oil filter and replaced it, checked the air filter ((no oil there, phew)... and it seems to be running fine after 3 engine hours (knock on wood).
My backstory is the lawn tractor was sitting in the garage with our car for two years and not used. I prepped it for long term storage, but failed to drain the carburetor of old gas, so the old gas gummed up the works (even with fuel stabilizer). When I did get it running (after changing everything listed above) a lot of smelly white smoke kept coming out, but as I let it idle in fast speed the engine strokes became more regular and the bouts of white smoke became fewer and shorter until the smoke stopped altogether.
Hopefully this helps!
Aug 10, 2014 | Craftsman Garden
Need help fixing a push mower. Worked fine before moving however since I got it back from the moving company it does not start. I've got it started a few times but it shuts off within a few minutes. ...
When it doesn't start have you tried to see if it will start on starting fluid? Sort of sounds like the symptoms of a fuel delivery problem. When you cleaned the carb did you take it all the way off the mower and make sure that the jets were good and clean? What type of mower are we talking about, and what style of carb?
Sep 01, 2013 | Garden
I drove my 85 ltd crown vic to work fine. After a long day of work she wouldn't crank just turn over. I have changed the distributive module and cap and the rotor button. The timing was reset also
is it getting gass if u got spark to the plug's it should start.dump alittle gas down carb or throttle body making sure to replace air cleaner or snorkle and try and start.if starts could be fuel pump.
Mar 03, 2013 | 1985 Ford Crown Victoria
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
Yamaha TTR 125 L won't idle
this is very tipical. when bikes are stored the fuel varishes up the jets & needles. soak the carb. moving it back and forth in the soak solution. then blow every jet and orfice with a controlled air source. note: any speck of rust or dirt can plug these jets. pay attention to detail and do every thing twice. then install the carb and adjust it to your riding style. later Spike
Nov 26, 2008 | 2004 Yamaha TT-R 125 L
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
54 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
