Question about Cameras
Not sure what it means w/the memory card is full. What shoild I do to use camera now?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey mrstena,
What this message means if the memory card you are using has no more space on it to record new images to it. To fix this you need to upload the images on the memory card to a computer either using a USB cord that connects the camera to the computer, or getting a card reader that supports your type of memory card and connect the memory card directly to the computer with the card reader. After you have uploaded your images you should format the memory card in the camera, which will erase all the images on the memory card and you should then be able to take more images. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 13, 2008
What does out of memory message mean on my nikon coolpix camera?
You have two questions here. Out of memory could mean that your memory card is full and you cannot take any additional pictures until you either replace the card with a new one, or delete or reformat the card you have in it. It could also mean that your card is "locked". Check for the little toggle switch on the side of the card to be sure it is in the "unlocked" position. Or it could mean that you do NOT have a memory card in the camera at all and you're using the very small internal memory your camera comes with (it usually will only hold about 4-5 images. If this is the case, put an external memory card in the camera.
The second part of the question deals with uploading to your computer. There are a whole host of reasons that can cause this. Here are a few.
1. Your software is configured incorrectly. It might be set for only a certain type of image (jpg, RAW, TIFF). It might be set to accept duplicate images and your images are already uploaded (somewhere on the machine).
2. It might be that your cord or connection is defective.
3. It might be that the computer is trying to find the external memory card and you don't have one.
4. You software might be looking for videos instead of images. Check your software configuration to be sure its set for image upload.
5. Be sure your battery is fresh. Some cameras will not upload with a weak battery.
6. The camera or software could be defective.
Aug 09, 2014 | Nikon COOLPIX Cameras
Internal memory full what does it mean.
It means that the camera's internal (built-in) memory is full and cannot hold any more pictures. If you want to take more pictures, erase some of them first (make sure you download them to a computer first if you want to keep them). Alternatively, if your camera takes a memory card, put one in.
Jan 17, 2014 | Polaroid Cameras
I have a Nikon Coolpix 5x camera. What does out of memory mean?
Most likely means the memory card is full.
Take the card out, connect it to your computer, click on properties and see how much memory is left on the card. If it is full you need to download or delete imags or anything else you might have on the card.
Jul 10, 2011 | Nikon Coolpix S550 10 Megapixel Digital...
Added new memory card. Camera says that the memory card is full..How do I correct this?
Assuming it is not actually full, this might mean the card is incompatible with the camera (too high a capacity) or it might mean it needs formatting. Usually a camera will say if it needs formatting, so I would check the camera specs to see whether you have a memory size it can handle. SDHC cards are not backwards compatible with SD cards.
Oct 22, 2010 | Vivitar ViviCam 3785 Digital Camera
What does "Memory Full" mean? The card was empty when inserted and only 1 picture taken.
Memory full means the internal memory is full and the camera won't let you use your memory card until you format the internal memory with no card in the camera.
Aug 17, 2010 | Casio EXILIM Digital Camera
My camera says internal memory is full...what does that mean and how do I fix this.
Your camera has a built-in memory for storing a small amount of pictures when you don't have a memory card in the camera. Yours is full. You can go into the menu and find "copy" which will allow you to copy the internal memory to a memory card for easy downloading to your computer. After you do this, you should remove your card, go into the menu and find "format"..follow the on-screen instructions to erase the internal memory and promise that you will never use it again. It's way too much trouble!
Jul 06, 2010 | Kodak EasyShare V1003 Digital Camera
Pictures cant be viewed says no image-then wont take pics says card full?
try the memory card in a card reader and plug it into a computer. see if the computer can detect the card and the contents in it. if it does detect it then that means there is a problem with the camera not recognizing the card or files in it. if it does not detect it in the computer that means the memory card of the camera is the one having problems.
Jun 09, 2008 | Vivitar ViviCam 3785 Digital Camera
Im trying to use the memory card but the camera says its full... I deleted everything and used a brand new card but it says the same thing. I even tryed formatting the camera..
Is it telling you the the card specifically is full or just full. Some cameras need to be switched from onboard memory to memory card. Also, if you are using a high capacity memory card make sure your camera can take a hgih memory card. If you put a 2 or 4 gb card in and it says full that means your camera can't use those cards.
May 27, 2008 | Fuji Cameras
Vivitar 550
Memory full means, if you have inserted a memory card, it is full and you need to delete or upload photos to your PC. If it is internal memory (*meaning you did not put a memory card in) then hook it up into your computer and upload the images. You can usually delete them by pushing the little green play button and then choosing delete all/one
Mar 03, 2008 | Vivitar ViviCam 35 Digital Camera
Casio ex-S500 memory full
Check the card to make sure it isn't "locked". SD cards have a tiny switch on their side which write protects them. If the card is "locked", then the camera can't write to it. See http://en.wikipedia.org/wiki/Image:Secure_Digital_Kingston_512MB.jpg for a picture of the locking mechanism. If this is not the problem, you can try reformatting the card. Although you can format it in your computer, it is much better to format it in the camera itself, since they are often finicky about the formatting details.
Mar 18, 2007 | Casio Exilim EX-S500 Digital Camera
Cameras Logo
77 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
