Question about Canon imageRUNNER C3200 Copier
Canon C3200 Hi Spinal, I read your solution to an earlier 8500 issue and appreciate your willingness and eagerness to help others! The problem had eventually went away on its own, so maybe it was a bad week or someone bumped the printer in passing by and knocked something back into place. Now my question is in reference to a 3200, which you seem to be well versed in. We used to lease one through Ikon, and after the lease ended my supervisor purchased a used one. He failed to get one with a C1 RIP. I had our tech department find and order a used one and am about to install it and test it. I read a post elsewhere on how to set the printer to open the RIP menu on the front panel via a setting in service mode. That post is now a dead link. Going into the menu, the only thing I can think to find is Option : Int-Face : Img-Cont : and set the value to "1". Is this the correct setting, or is it somewhere else? Also, we are a fairly small company and our main reason for purchasing used printers is because leasing is just not as good an option for us. Therefore, I actually have taken on some of the duty of delving into the printers and fixing them myself when needed. I do miss the techs though! They were always fun to talk to. I know it may be against policy but I've been looking for a source where I could read what each of the service settings are for, what they do, etc, and any type of service manual. I'd once ran across a manual online for a 3300 (or similar) but it wasn't quite the same as the 3200). I do appreciate any help or advice! Thank you, Jeremy Swanson jeremy@creativemk.com (800) 605-4280
  • 86 Answers
Set the img-cont to 3 in int-face
If You require further assistance please get back to me
Thank You
Posted on Jun 23, 2008
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Oct 08, 2015 | Canon Office Equipment & Supplies
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
Hello, I have a problem with my c3200! looks like yellow, and color looks faded. The image I'm trying to print looks all faded. Any help would be great thank you for your time
Try running the gradient/color adjuster (do a full test). It's in Additional Functions screen.
The C3200 series is known for this and many other issues. Most of the customers that I met has since switched to a Xerox color machine that has much better results (Docucolor series for print shop/marketing type work, and the WorkCenter 7600 series for high end office work. Both same body design, different engine/system software)
Nov 25, 2009 | Canon imageRUNNER C3200 Copier
I don't know which Canon camcorder to buy. I like
I haven't fixed the problem yet but will go to several stores and speaks to the sales people there. I don't fancy paying $20.00 for this service over the internet much as I appreciate your willingness to be of help. Perhaps another time!
Jun 24, 2009 | Canon ZR850 Mini DV Digital Camcorder
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Problems with Canon IRC3200 printing issues
you need to go into servie mode to check the drums, your problem is you need a drum unit if the copiers are shading.
canon tech
Feb 19, 2009 | Canon imageRUNNER C3200 Copier
C3200 COLOR PROBLEM
3 possibility 1-your secondary transfer is dirty or needs changing 2- your primary transfer sheed is damage or your fixing assy. is damage go with number 1 first try cleaning with a clean dry rag then blow away any lint. for service mode press and hold additional function at same time hold down 2 and 8 then add function again
Nov 19, 2008 | Canon imageRUNNER C3200 Copier
Introducing Myself : The 8500guru
I own one of these, if I run into trouble, I will be looking for you!
Jan 04, 2008 | Dell Inspiron 8500 Notebook
Where's the meter?
Press the button marked [123] above the numeric keypad on the control panel for a list of machine meter readings.
Sep 05, 2007 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Copier Logo
125 people viewed this question
old marine
old marine
