Question about Konica Minolta magicolor 2300DL Laser Printer
How do I change the OPC Drum cartridge? I cannot find any instructions to get to it.
Open the front door.
Remove the toner waste bottle.
Turn the belt tightening knob (top middle with arrow on it).
Pull out the OPC Drum.
Install new OPC Drum.
Turn the belt tightening knob back.
Re-install a waste toner bottle.
Close the front door.
Posted on Nov 19, 2010
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: OPC Drum
Sometimes the flap that covers the drum gets bent and catches on the side of the printer, I use a flat screwdriver to pry it out
Posted on Oct 10, 2008
SOURCE: to change opc drum in konica minolta
Search the web for the users guide. Instructions are under "replacing consumables"...dvw
Posted on Feb 24, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: is the "change drum soon" message instructing to
This indicator is for the drum unit, not the toner cartridge. The drum unit is the assermbly that the toner cartridge is inserted into when being replaced. The drum unit is replaced about every 18,000 pages so after about 5 to 10 toners have been replaced.
Here is a picture of the drum unit.
Posted on Oct 28, 2010
  • 304 Answers
SOURCE: Part number for the OPC
That OPC is the same for HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415 cartridges.
No Part number, search OPC HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415.
Posted on Jul 04, 2011
1020 drum laserjet
The OPC drum is contained inside the toner cartridge.. just buy a new toner cartridge! OPC stands for (Organic Photo Conductor) and its part of the toner cartridge.. Buy a new cartridge HP order number is Q2612X or aftermarket
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Feb 04, 2014 | HP LaserJet 1020 Printer
How to change the drum cartdrige.
Remove the imaging unit ,remove the charge corona assy,remove the OPC drum,remove 2 screw and dump the developer out.Reinstall the imaging unit ,pull out the toner cartridge and push in toner cartride ocation the developer cartridge.Turn on the copier and wait then the copier perform the new developer initialization.Whwn the Start button in ready(green light),change the developer cartridge to toner cartridge.
Mar 05, 2013 | Minolta EP1031/1031F CS/PRO Copier
Part number for the OPC Drum in a HP toner cartridge CC530A.
Jul 04, 2011 | Office Equipment & Supplies
12A cartridge after refilling is printing ghost print repeating ...plz how to rectify problem.. what is the problem....
replace cartriage then you can identify the problem is in printer or cartriage if the problem is in printer the problem creater is teflon sleeve. In other case the problem is of opc drum Change the cartriage opc drum then check
Jan 01, 2011 | HP LaserJet 1010 Printer
Poor copy quality - smudgy copies - changed toner - still the same.
check your OPC drum life, if you have a poor quality with a new cartridge installed (light copy, dirty copy) the opc drum must be replaced, check you machine counter if you have reach 100k copies you need to replace the drum, if you are using a new OPC DRUM, you need to clean the machine, you have to call for service because there is many parts that muat removed to clean properly.
Dec 27, 2010 | Canon NP 7130 Black and White Copier
I have a 'service call 17h' error condition and was about to use some FixYa instructions that worked last time but this time i am unable to get past first-base, i.e. i cannot remove the OPC drum cartridge...
open the front door and remove the waste toner bottle and transfer belt. use a flat bladed screwdriver in the small hole at the 10 o'clock position of the hole where the toner cartridges are installed. this now allows you to rotate the toner carousel slightly to free the OPC drum and remove it. you will probably find that a toner is not in its slot correctly and jammed against the drum causing the error 17h. use the release mechanism to rotate the carousel and remove all of the toners. check them for any damage, also the OPC drum, power up the printer and refit the parts as requested on the display, being very careful to put the correct toner in the correct slot.
Aug 07, 2009 | Konica Minolta magicolor 2300DL Laser...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
OPC Drum
Oct 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
Four dots middle of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Sep 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
How do you change the drum cartridge ?on a 2300 qms minolta printer
Replacement of the OPC Drum Cartridge
1. Open the Front Door.
2. Remove the Waste Toner Bottle.
3. Lower the unlock lever and remove the Drum
Cartridge.
4. Reinstall the new Drum Cartridge
5. Pull the protective sheet of the Drum Cartridge to
the front and remove it.
6. Raise the unlock lever.
Jun 09, 2008 | Minolta magicolor 2300W Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
295 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
