Back to:
Tags:
Kitchen Ranges
Generic problem for all Kitchen Ranges
GAS RANGE
posted by msmaytag on Jun 13, 2008
The inside of my gas oven is turning black with soot. It has been converted to propane use, the top is fine. It is a 6 month old Maytag Gas Range. Thx
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 13, 2008
FixYa! (100)
textonor
Rank:Guru Guru
Rating: 89%, 96 votes
Msmaytag it sounds like the oven wasn't converted properly if at all to propane. If you look at the bake burner while the oven is on you should see very little yellow on the flame. If you see mostly yellow, try adjusting the air to more open. This will changed the air/fuel and may resolve the issue. If not, follow the directions for converting to propane and see if the orfice hood was either replaced or tightened down. I am not quite as familiar with the maytag is why I ask you to follow the directions. The issue with propane is that it runs at 10wc instead of the 5wc of natural gas. So double the pressure, you need more air to thin the fuel. Hope this helps.
Rating Locked! (?) msmaytag has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on GAS RANGE:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
Kenmore 96422 / 96424 / 96429 Electric...
can set timer but how do you start it?
Kitchen Ranges
we are switching from Propane to natural gas and the stove...
Maytag MGR6772 Gemini Gas Kitchen Range
it was working fine last night but when I woke up this...
Kitchen Ranges
wirlpool oven accubake system problem code E3 F1
Kitchen Ranges
Broken bracket holding handle to oven door
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
