Question about Craig CVD327 DVD Player
Excuse my ignorance but . . . I have a dvd player and tv that support S-video however how do I connect the sound?
    Sergeant:
    Champion:
  • 387 Answers
Why you want to connect S Video
you should have a cable with 3 connectors YELLOW WHITE RED
connect the cable from the DVD to the TV match the color on the Cable to the connector on the DVD and the TV
hope it will help
Posted on Nov 04, 2010
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
DVD model #mwd7006 sound but no picture
  • To reset the DVD player unplug the DVD player for 10 seconds.
  • Confirm that the TV has been set to the corresponding video connection of the DVD player.
  • DVD player has three video outputs.Video, S-video and RGB-component.
  • If current connection to TV is not working and the TV has an alternative video consistent with the DVD player try the second.
  • Try DVD player on another TV
Nov 24, 2015 | Televison & Video
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
Sony DVP-NS575P DVD/CD player
Hook the Yellow, Red and White cables properly in both TV and Player. Play the DVD Player and select A-V Input by TV remote at TV.
Aug 10, 2008 | Sony DVP-NS575P DVD Player
Speaker Connection
Put teh wire of the cable in the side of the plugs once you have untwisted them - they dont come out.
Feb 16, 2008 | Cambridge Audio Azur 540D
Sound through tv on M280 portabel dvd player
Do you have both video and audio cables connected? Yellow or S-Video cables are only for video, you also need to connect the red and white RCA connectors on player and TV for stereo sound.
If you have already done this, check the player's menu to see if there is a setting for external or auxiliary audio.
Jan 26, 2008 | Amphion Mediaworks M-280 Portable DVD...
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Craig CVD327 DVD Player Logo
88 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
