Question about Sharp Video Cameras
Urgent. I have a Sharp ViewcamZ about 6 years old and it is a great camera. However it often comes up with a dew warning which won't go away. I have tried leaving the camera in a room for over half an hour which the manual says should fix the problem but that doesn't work. I have tried storing it in hot water cupboard and it seems to work for a while but to day I checked out playing about 5 mins of 3 tapes to see if they could be used for my Daughters wedding this Saturday 6th Nov. After 3 tapes the dew warning appeared and won't let me do a thing. Is there anything I can do to make sure the camera is ok for Wedding?
  • 567 Answers
I would suggest that you get the device serviced by the manufacturer.
There is, however, a way which has many reporting success.
You will need to solder the dew sensor to reset it and it might help you.
This process involves using the soldering iron and you should only attempt if you are handy with those. The incorrect use can render the camera in need of a big repair.
If you would like to try, please follow the steps outlined on this page.
There are pictures to help you in identifying the parts too.
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Nov 04, 2010
When i turn the camera on the word Dew flashes for about 3 seconds then the camera turns off,
Hi - Sorry your having problems with your camera. I'm assuming it's a video camera. the DEW warning is telling you there is excessive moisture in the camera. I suggest you take out the tape and leave the tape door open in a dry warm place for a couple of hours.
You could also take a hair dryer on LOW and keeping it at least six inches from the camera move it back and forth over the tape compartment for a minute or two.
Sometimes the DEW message comes on when there is no such problem which is a problem with the camera that will probably require service.
Good Luck, Mikeywaf.
Mar 02, 2011 | Sharp Cameras
WHEN I TURN ON THE CAMCORDER IT SAYS DEW
Hi, dew mean its the humidity sensor is on
thats lock all operation/ you can try an air dryer
:/open the loading tray if you can and blow at medium hot ,some hot air in slot for mechanism for few minutes avoid to be to close off the pastic cassing
and leave it rest for a few minutes and try it...
if wont work that is the dew sensor it self defect
hope that will help
Mar 29, 2010 | Sharp Viewcam VL-Z1 Mini DV Digital...
I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Sep 18, 2009 | Cameras
Get "DEW DETECTED" warning on screen, powers off.
Also try this, take the bottom cabinet off, with the lcd panel facing you and the camera turned upside down and the cassette housing pointing away from you you will see 2 wide gold cables plugged into the right side of the board, realitively the same size, the gold cable that is between the main pcb and the mechanism assy is the control cable pull it our of the connector and clean it with alcohol, you can even take it one step further and evenly trim just a hair of the cable off all the way across just so that it has a new place to set. This has worked for me over 100 times in the past years. Seasoned camcorder technician 13 years experience.
chrisveal@msn.com
Aug 13, 2009 | Panasonic PV-DV103 Mini DV Digital...
DEW Message & shuts off
I opened & then closed the Video Cassestte door & it seems to have taken care of the issue.
Aug 01, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
PC101E - Dew Sensor flashes up when I switch on the camera
rub the dew sensor with q-tip & alcohol and the condensation warning should disappear!
Mar 18, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
Dew
Model: VL-Z800 Sharp ViewcamZ
I was in Shanghai in Dec 2008 over Christmas and I experienced the 'DEW' problem. The cassette tape door would not close either. I did not experience this before even after 2 years. I suppose the cold & the rain water causes the dew to accumulate in the CAM.
Solution.
I did the reset by taking out the small tiny battery situated just above the big battery. The small battery has a cover. Pull it up & Get the small battery out and the whole camera resets. Re-entering the date & time is the only inconvenience. After reseting, I could use it again, but not for long as the problem comes back. When I came back to Malaysia (Temp 32-34 degrees celsius), the DEW problem disappappers.
You could also try this method to get rid of the dew. Buy a small sack of rice. Yes rice, the uncooked ones. Cut open a small opening just big enough to put your CamCorder into the sack. If you do not want to get your CAM dirty, wrap the CAM with tissue paper. Close the opening with a musking tape and leave it a few days. The dew should disappear from the CAM. It works for mobile phones too when it is accidentally drop into water. Of cause you should not switch on the mobile when it is still wet. It will self distruct if you do. Try the rice solution for a week before you on your mobile.
Rgds/ T.S
Dec 17, 2007 | Sharp Viewcam VL-Z1U Mini DV Digital...
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Video Cameras Logo
99 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
