Question about Garden
I have a model 44-1010 Brinks timer, when I tried to reset the time it seems to be confused, I thought I set tyhe time and proceeded to program the on/off time and it now locked up at 1:00 am time off. The buttons do not function. The internal battery seems to be weak, so I have it on an extention cord to view the display. Is there a way for a master reset?
SOURCE:
SOURCE: Display dies, although phone still functional
My razr V3 dropped from an astonishing 40cm to the floor, after that both screens stopped working. I opened the screen by removing the four tiny screws in each corner (t5 screwdriver which I didn't have but the smallest of my miniature screwdriver set just fitted), and popping it up carefully. There a two flatcables, one with a silvery color and a connector with a black piece of foam on it. I think it's the screen signal carrying cable. I removed it and put it back in place, pushing it firmly. After that the screens worked again. 10 minutes of work and a great deal of satisfaction. Further, the phone stinks. regards, El Rudo
Posted on Feb 12, 2007
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Posted on Sep 16, 2008
SOURCE: Security Lock for Master Reset
enter the security lock code 000000 try it! it worked in my phone
Posted on Oct 29, 2008
SOURCE: I've misplaced the instruction manual for my new timer.
call 1-800-562-5625 they will email instructions to you ....
Posted on May 19, 2009
SOURCE: Brinks model 44-1050 digital outlet timer- I don't
I have an instruction for a Brinks 44-1030 which I believe programs the same. If you email me at tedban@gmail.com I will send you a PDF scan of the instruction.
Posted on Jan 08, 2010
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
How to set timer the Brinks 44-1011 timer.
Often the reset button is small round hole
http://waterheatertimer.org/Brinks-timers-and-manuals.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 29, 2014 | Hardware & Accessories
Brinks 46 1022
The timer could be defective
Nov 09, 2013 | Hardware & Accessories
Setting the clock on a brinks timer 44-1011
I finally found the instructions for the Brinks timer 44-1011 and they work.
    • BRINKS DIGITAL TIMER 44-1011 INSTRUCTIONS
    • CURRENT TIME SETTING
    • 1*Press and hold the OK button for 4 seconds. Hour Display flashes.
    • 2*Press +/MANUAL or - to select the hour. Press OK to confirm.
    • 3*Minute display will now flash. Press +/MANUAL or - to select the minute. Press OK to confirm.
    • 4*Press MENU to exit the time setting mode. Now the timer is in clock mode.
    • PROGRAM SETTING NOTE: This timer can be set up for up to 2 different programs. We will use PROG 1 for this example, however these steps can be repeated for any of the 2 programs. To cycle through the individual programs use the +/MANUAL or - after pressing MENU in step one until the desired PROG "#" is flashing. To clear a program setting hit the RECALL button when you have the program selected.
    • 1*Press MENU button, PROG 1 "ON" will flash, press OK.
    • 2*Hour will flash. Cycle with +/MANUAL or - to desired hour, press OK.
    • 3*Minutes will flash. Cycle through minutes +/MANUAL or - to desired minute, press OK.
    • 4*Program will be flashing again. Press +/MANUAL to get to PROG 1 "OFF" blinking, press OK.
    • 5*Repeat steps 2-4 to complete PROG 1 setting.
    • 6*When done setting programs press the MENU button to return to clock mode.
    • 7*Press +/MANUAL to have LCD showing either "AUTO ON" or "AUTO OFF" for the timer to execute the programmed settings.
    • DAYLIGHT SAVING TIME SETTING (DLST)
    • 1*In clock mode, press RECALL to turn on or off the Daylight Saving Time.
    • 2*Turn on DLST, the below of LCD shows +1H. Time is adjusted by adding one hour.
    • 3*Turn off DLST, +1H will disappear and LCD shows the real time. MANUAL OVERRIDE AND ALWAYS ON/OFF When in clock mode the +/MANUAL sign cycles through
    • 4 settings that serve as manual override. **ON - Indicates that the timer is in the ON mode, and will always be on regardless of the programmed setting. **AUTO ON - At this selection, the timer will come on regardless of the programmed setting, but it will follow the next programmed command. **OFF - Indicates that the timer is always off (i.e. the wall socket is turned off) **AUTO OFF - Indicates that the timer is in the OFF mode until the next programmed step that turns it ON.
    • NOTE: For normal timer function, the selection must be either "AUTO ON" or "AUTO OFF". RESET At any mode, press RESET for 5 seconds. All settings will be cleared, return to clock mode, 12:00 MO, AM, AUTO OFF will be shown on LCD
I hope this is helpful. It was a bear to find.
Dec 24, 2012 | Hardware & Accessories
Setting the timer on the Brinks timer model # 42-1006
The way to set it is two-fold:
1. pull out the tabs for the times you do not want the light (or other) to be on. The tabs that are left in will be powered.
2. Set the time of day by turning the know to the indicator arrow.
Nov 30, 2012 | Hampton Technologies Brinks Timer
I have the brinks timer model 42-1009 can you tell me how to program it
Copy following link for setting timer:
http://waterheatertimer.org/How-to-set-timers.html
Jun 04, 2012 | Hampton Technologies Brinks Timer
Progaming brinks timer 44-1073
Timer is not identified:
Check options below
1) Add a comment and describe timer in detail, and include photo of timer posted on Flickr for possible identification.
2) Contact Hampton Products.com for possible manual.
Sometimes they respond, and sometimes not.
http://www.hamptonproducts.com/contact-us.php
3) Open following link for Brinks manuals that is updated as new manuals arrive
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
http://waterheatertimer.org/pdf/Brinks-44-1010-manual.pdf
4) If you are looking for a manual to post on your site, I cannot find one at this moment.
5) If you have instruction sheet and need help programming timer, then add a comment and say what part of instruction is confusing, or take advantage of fixya live help and expert speaks with you over phone while you program timer.
Sep 30, 2011 | Hampton Technologies Brinks Timer
Need how to use my timer. Brinks digital plug in home timer. Model # 44-1020. 6 settings per day. Battery backup
Manual appears on following links:
http://waterheatertimer.org/pdf/Brinks-44-1020-manual.pdf
The manual has important illustrations, and has more words than allowed for free answer.
Open manual and get as far along as you can, and then add a comment where manual is confusing and I will help.
The battery is rechargeable type, so plug timer into outlet for hour and then unplug timer to set programming.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Hampton Technologies Brinks Timer
Have a timer that I can't get programmed. It is Brinks 42-1005, the serial # may be 1009C-A but we are not sure as there is no label for that number. The instructions were thrown out and there doesn't...
Move the dial clockwise until the arrow (marked TIME OF DAY) is lined up with your present time. Numbers on dark gray background are night time hours. Depress outer "teeth" that also correspond with hours of the day & evening (ea. tooth = 1/2 hour) for the chunk of time(s) you want the appliance ON. Plug timer into outlet and appliance into timer. There is a manual TURN ON slide switch on the left of the timer for your convenience as necessary.
Jan 25, 2011 | Hardware & Accessories
Garden Logo
273 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
