Why is it neccessary to off the fan while performing an experiment
  • 93 Answers
Could you be more specific? what experiment are you trying to run and what do you mean by " off the fan" which fan?
Posted on Nov 04, 2010
95 Silverado is making noise as if fan is rubbing on shroud. Begins noise after 45mph
With vehicle off grab fan and wiggle, should not have lateral movement. If it does inspect fan clutch and water pump to see which bearing is loose replace as neccessary
Oct 18, 2015 | Cars & Trucks
Activation code for autocad 2012
As you approach to the point when the trial (unactivated) AutoCAD license expires (30 days between the installation and activation of your license), it may be neccessary to activate your license "on the fly", inside a running AutoCAD session (not on the AutoCAD launch). You can perform the activation with the ABOUT command. Click the buttons About the product > Activate and you'll get to the dialog "Autodesk Licensing", which is usually displayed on AutoCAD startup:
a2011activ1.gif Click the Activate button in this dialog. If you have received your activation code over e-mail, pick the option I have the activation code from Autodesk and in the numbered fields 1-16 enter the hexadecimal activation code from the e-mail. It is not neccessary to manually type-in the individual fields - just copy/paste the code as a single string (some fields may remain blank). By finishing the activation you will get back to your running AutoCAD session. a2011activ2.gif
Jul 14, 2011 | Computers & Internet
My phone saying not enough memory to perform operation. deleat some data first
Yes you have to delete some infromation you feel are not neccessary again on your phone to be able to create space for the phone.
Feb 10, 2011 | Nokia 5230 Cell Phone
My laptop is not connecting to the router but all other wireless applicance are getting a signal what do i need to do
The router may be malfunctional. Perform power on restorations fucntionalitie as checks of devies fucntionalities. Second, the router becomes neccessary with additinal computers requirng signal exchange. A new computer on the network would derive signals from the router when turned on.
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
When I turn the jeep on there is a sign saying perform service???
That's right! Your Jeep has a onboard computer that controlls all the power units, the engine and the gear box. As shown in your driver manual you have to perform the engine service ever 6- 8 - 10 or 12K miles. And your Jeep reminds you, that the service is neccessary. To perform the service right on time will save you money on fuel and spare parts, let the engine run smuth and below the limits of green house gas emissions.
Change the oil filter, the engine oil, check the spark plugs, coolant water, servo oil, serpetine belt and you battery cable connections and the battery too. If you can't perform the service by your own, ask for the next dealership or service point. You'll find it at jeep.com too
Dec 17, 2010 | 2001 Jeep Grand Cherokee
Radiator fan motor going out
you can get a replacement fan motor and it might cost $68 to $132 ...these are fairly common and a very neccessary item for proper cooling system operation
Jun 28, 2009 | 2007 GMC Yukon
Get restarted again and again laptop
Problem 1: Loss of either the power supply fan or the CPU fan can create that problem.
Problem 2: Windows XP may not have the SATA driver on the setup disc for your machine thus the install doesn't "see" a drive. There is additional info at this link (at the HP website) about how you can integrate the drivers into your XP install.
You shouldn't need to load Vista again but most likely you could use a dual boot for your machine if you wanted to. For the fan issue you may want to place it into service if you aren't comfortable taking apart a laptop for checking or replacing a fan. Generally the parts can be sourced online for your machine (and usually cheaper than through a service facility) but it comes down to comfortability with the replacement procedure when deciding to put it into service.
Mar 04, 2009 | HP Computers & Internet
Computer statting problem
- Boot system normally, go to RUN type msconfig, uncheck all application that are not neccessary to run behind the windows.then reboot system normally.
- System should normally run under better performance.
Oct 05, 2008 | Microsoft Computers & Internet
No Fan
If you here a click then check the Relay, open and turn on you should see a black box with wires going to it, (Careful HIGH VOLTAGE!!!!)
Jul 18, 2008 | Danby DPAC8399 Air Conditioner
Computers & Internet Logo
12 people viewed this question
Alun Cox
David Payne
David Payne
