Question about Gigabyte GA-K8NS Motherboard
Installing 2 sticks of 1 gb ram = DRAM error beeps
I have an on going problem when installing ram.I hear long continuous beeps. I have had the same 2x1 gb sticks working together before. I have just replaced the psu and had the same problem / in the past the same when i replaced the cpu. I checked the grounding posts and found one loose and replaced the post, tightened and installed everything hoping that this maybe the issue. But when i press in the sticks of RAM i get these beeps. I'm running just the 1 gb stick at the moment but when i attempt to install the second stick i hear the same beaps.... please help.
Hi ive got a memory problem too. i have 3 x 1gig memory, samsung. bios/boot recognises the memory but windows doesnt start. when i remove 1 stick from the 3rd slot everything runs fine. please help!
Posted on Jul 13, 2008
  • 2,794 Answers
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Posted on Jun 13, 2008
Long beep continuous
here is a list of beep code for Award bios chip, which is the one present on you memory card:
repeated beeps - DRAM error
repeated short beeps - Power error
Repeated high & low beeps - Processor is damaged/Overheated
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
I don't remember the speed of the repeted beeps for the award bios.
But in your case if this is not a DRAM issue, you might try to check if the beeping remain the same once the cmos battery removed (the flat batterie that looks taken out of a watch).
If so this means that it needs to be replaced.
Oct 20, 2013 | MSI PM8M-V Motherboard
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
When I turn on my computer i hears a few double beeps and I don't see anything on my monitor while computer sounds like it running
Here is a link for with some information for the GA-M55plus-S3G motherboard:
http://china.giga-byte.com/FileList/Manual/motherboard_manual_ga-m55plus-s3g_3.x_e.pdf
The below was taken out of the document:
The beep codes below may help you identify the possible computer problems. However, they are
only for reference purposes. The situations might differ from case to case.
�� AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Jul 07, 2009 | Gigabyte GA-M55plus-S3G Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
At POST I get 2 short beeps
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
AMI BIOS:
1 short beep: DRAM flash error
2 short beeps: DRAM ECC check error
3 short beeps: DRAM detect error
5 short beeps: CPU error
6 short beeps: Keyboard error
8 short beeps: Video card error
1 long and 3 short beeps: Bad DRAM
1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
BIOS Beep Codes
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
AMI BIOS
# of Beeps Error Description
1 Refresh Failure The memory refresh Circuitry is faulty
2 Parity Error Parity error in the Base (1st 64K) of memory
3 64K Base Memory Error Memory error in the base memory (1st 64K)
4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
5 Processor Error CPU error
6 8042 Gate A20 Failure Unable to switch to protected mode
7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
9 ROM checksum error The ROM checksum does not match that of the BIOS
10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
IBM BIOS
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error
1 Short Beep Normal POST, System booted OK
2 Short Beeps POST Error - Code on Display
No Beep Power supply or Motherboard error
Continuous Beep Power supply or Motherboard error
Repeating short beeps Power supply or Motherboard error
1 short, 1 long beep System board error
1 long, 2 short beeps Display adapter error (MDA/CGA)
1 long, 3 short beeps Display adapter error (EGA/VGA)
3 long beeps 3270 keyboard card
Phoenix BIOS
The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
4 seconds long beep
I think that either you have a bad power supply or it is not connected properly. I suppose it could also not be supplying enough power.
Try disconnecting all of the connections to the Motherboard and reconnecting them. Make sure they seat properly. Try a new power supply. You can get a good one from Newegg.com
Jan 26, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Gigabyte GA-K8NS Motherboard Logo
269 people viewed this question
Top Gigabyte Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
