Question about New Balance Balance 1500 Treadmill
My new balance 1500 treadmill works great but the last couple days its starting to make a clickinng noise around the belt. It sounds like its tranfering from the motor area. The belt has never been tightened but appeared to have decent tension. the belt is good, but could the tightning stop the clicking? any advise or a web site with a manual. thanks JOEL
  • 297 Answers
It sounds like you have a bearing failing, either in the front roller or the motor. If it is the front roller it will be a dull "Clicking" noise, if its the drive motor it will be a growl noise. The growl will be so loud at top speed you wont be able to even talk over the noise. Remove the motor hood and this will help you determine the culprit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 04, 2010
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
My New balance 1500 is stuck at the highest incline postion
Contact manufacturer, sounds like a defect with machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
May 06, 2014 | New Balance Balance 1500 Treadmill
For the last couple of days tread belt seemed to be pulling a bit hard and smells a bit of burning when stopped,tonight i switched on bit of a clunk and belt would not turn kicked foot on belt it started...
treadmill belt need always to put a special oil from below, for better sliding. it is a special product you can find it at any service center for treadmill.
Nov 15, 2013 | Exercise & Fitness
Lubricant needed for new balance 1500 treadmill
1) the deck belt can be use 100% silicones or wax if your model use wax.
2) rollers bearing use WD-40 or similar for lube bearing.
God bless you
Nov 29, 2012 | New Balance Balance 1500 Treadmill
My tread mill stop working i have green light in the electonic board 5 small light not on
You need a new controller board. You can check your manual for how to order replacement parts. It will not be available on the New Balance website. It will actually be from an off-brand treadmill manufacturer that made the treadmill for New Balance.
Oct 22, 2012 | New Balance Balance 1500 Treadmill
Where can i find replacement wires for treadmill
go please to www.treadmillpartszone.com or www.fitnessrepairparts.com
God bless you
Jul 02, 2012 | New Balance Balance 1500 Treadmill
How do i fix my belt, is bowing up on my NB 1500 treadmill?
There are two knobs on each side at the end of the treadmill deck. Twist those knobs to tighten the belt. You will need to tight both sides. The little meters show you the amount of tightening you have done. They're most useful for making sure you have both sides tightened the same; otherwise the belt will be lopsided and slide to one side or the other.
Jan 26, 2012 | New Balance Balance 1500 Treadmill
I need a replacement walking belt for my NB 1500 treadmill. How do I get this part?
You can order one from treadmilldoctor.com or from Amazon. Just measure your deck length, thickness, and width then search for a matching belt size.
Oct 22, 2011 | New Balance Balance 1500 Treadmill
New motor board and the belt pulses
It sounds like the unit speed sensor is out of adjustment or the connections is not secure when replaced the new board and last thing some units sometimes need a calibration to tell the upper console to synchronize with the lower board.
Apr 11, 2010 | New Balance Balance 1500 Treadmill
New Balance Balance 1500 Treadmill Logo
1,260 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
