Question about Maytag MER6772 Gemini Electric Kitchen Range
Bottom oven element on Model MER5552BAW
The bottom element is not working. How do I tell if it is the control board or the element. I know about checking the element w/ a multimeter and looking for infinate resistance, but how do I know if it is the controller on the circuit board? The top element is working in the oven. The oven fails to heat up to the designated temperature. After 1.5 hour, the oven has only warmed up from 100 to 175, when the temp was set at 400.
Thanks in advance
  • abbalaw Jun 23, 2008
    all the electronic part works but the oven itself does not go beyond 120. the fan for the convection , the picture i mean, turns but the actual fan is silent. Nothing really happens except for a little warm on both ovens the top and bottom but on top everything seems to be responding. No temperature so what do we do or what can we do?
    President:
  • 878 Answers
Magic, start with the basics first. See if you have the right power going to the oven. At the terminal block on the oven, where the cord attaches, you should have 120V from the center terminal to each end terminal. You should have 240V across the 2 end terminals. If you don't have this, there is your problem. If that's ok, check the voltage at the bake element terminals in back. Should be 240V when in bake. If that checks ok, then it would be the element itself. Check it, with power off and wires disconnected from the element it will ohm at approx. 20 to 22.6 ohms. If you don't have the power at the element then I would suspect the oven controller. The fact that it's heating to 170 degrees leads me to believe that you are missing a leg of power. Catriver.
Posted on Jun 13, 2008
Will just replacing the oven element fix my Kenmore model 911.955879range oven? It sparked, broke in two and a white flame continued going around the element, wouldn't stop I had to shut breaker off.
Hello Jennifer;
My name is peter. I am a retired field service appliance technician.
Good for you - turning off the breaker.
You have a older oven. Usually there is a spark or crack in the oven element. In your case the element was so embrittled it broke into 2 pieces.
Before you use the top range burners to be on the safe side you need to disconnect the oven element. You may have damaged the oven control board to where it is locked into power for the oven.
25713262-01ium3bsyoj5ql4fhv4kpwvp-4-0.jpg 1.) Remove the bottom drawer to reduce weight.
2.) Put a rug on the floor in front of the oven, so when you pull the oven out it does not scratch the floor.
3.) Pull the oven out so you can get behind it.
4.) Unplug the unit.
5.) Remove the back bottom cover.
6.) Disconnect the heating element and remove from oven.
7.) Rap the two loose element connections in the back with electrical tape.
8.) Follow the element loose connection to the control board at the top. Disconnect at the oven control board.
9.) Inspect the loose wiring from the control board to the heating element for burns or melting.
10.) Plug the oven back in and turn on the range burners.
The part number for the oven element is WB44T10014. Sears wants about $95.00 for this part. Search the internet for this part number and get it for about $28.00.
Your oven control board may have become damaged. Recently I replace one for a friend. Sears wanted $256.00. I got a remanufactured board over the internet for $30.00.
Get back to me and let me know what is going on.
May 25, 2015 | Kitchen Ranges
I recently replaced a bottom baking element in my maytag oven. (Model #mer5552baw.) Now my oven will not preheat, but the stovetop still works. Does any one have any idea on what the problem might be???
Do you still have a display on the control if so good verifies 120 volts to control easiest way to test go to terminals on element with a meter you are looking for 240 volts at terminal when bake is turned on if no voltage either a broken wire or control board is not outputing on one of the heat relays
Feb 20, 2015 | Maytag Kitchen Ranges
I have a Maytag electric oven model MER5552BAW. Bottom bake element blew out. I replaced the element & now oven will not heat at all. Going nuts!
Go to youtube and type in your model number and ask for repair videos:
https://www.youtube.com/results?search_query=troubleshoot+Maytag+electric+oven+model+MER5552BAW
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both.
I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg.
Jim B Roseville, CA.
Jan 31, 2014 | Dacor Ovens
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire wall over model number CGEB30S8AB1 is not heating. It is just the bottom bake element. I tried to replace the element but it is still not working. I can hear the relay clicking but it will...
I had this problem a year ago (both elements worked in top oven but only broil element worked in the lower of the dual ovens). I swapped elements around but the problem was still the bottom element bottom oven.
So I called the repairman. He replaced the relay board (Part #AP2127301) for the lower oven, and it worked again. Yippee.
But now a year later, I have the exact same problem. Lower element on lower oven is not working (Frigidaire you have got to be kidding)!
However this time I decided to take a look at the relay board myself, to at least save the expense of the repairman. I looked closely at the board and thought I saw a cold solder joint on relay K4. But just to be safe I touched up all the connections on all the relays with flux and a soldering iron.
Works perfectly again !!
Please if you try this, disconnect the power first. In fact if I had to tell you that, then just call somebody.
Oct 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
My 4 top elements work but my oven doesn't.
Take the back cover off the range. Locate the bake element terminals near the bottom of the oven. Turn bake on and check for voltage. If no voltage then replace control board. If voltage is good, then unplug oven and check for continuity. If no continuity then replace bake element. Also, does broil element work or is it dead as well? If both oven elements are dead then the control board is most likely at fault.
Aug 10, 2009 | Frigidaire FEB27S5A Electric Single Oven
Fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Jun 30, 2008 | Frigidaire 30 in. Electric Gallery Series...
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Maytag MER6772 Gemini Electric Kitchen Range Logo
271 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
