SOURCE: maytag neptune mah8700aww wont drain, spin or put water in
if you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
