Question about Motorola Mobility RAZR V3
Battery not charging
Just received a new battery ans after 5 min it indicated low battery. When I tried to charge it, It would not charge. What is my next step. I just got this phone and still haven't been able to use it.
  • Anonymous Jun 30, 2008
    We have been having this same problem. I bought a brand new battery. Took it home, charged it up, within 2 hours the phone battery died. I charged it again and it said Charge Complete. We have brought the phone back to the Sprint Store twice and they replaced it (suppos
    edly) but it's still not working properly. We are going back to the store again today to see if they can fix it or get us a new, different phone type.
    Brigadier General:
  • 7,752 Answers
STD - you need to clean your usb port that allows you to charge the phone........or take it to ahve it lookeed at.
GUEST - get a brand new phone instead of having it service
Posted on Jul 02, 2008
Battery light flashes green 5 times, then changes to orange.
The flashing green indicator is telling you (and the notebook) that the battery is almost fully charged, but then by switching immediately to flashing orange, the status has changed to "battery charge is low". This is not normal behaviour and probably indicates a serious issue with the battery. My guess is that the charging is initiating some kind of rapid battery self-discharge.
Ref - Knowledge Base
Notebooks will power up and work without a battery just fine.
Ref - Laptop Battery Basics dummies
Try to operate yours this way. This will eliminate the battery from the loop as a potential cause of the BSODs you are seeing.
Jan 09, 2018 | Dell Latitude D610 Notebook
Cobra Mirco Talk CXT 195
pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Jan 15, 2014 | Cobra Radio Communications
When my acer aspire 5734z laptop is plugged in the charger indicator flashes and the battery indicator shows blue.it stays at 0% and says plugged in,not charging.if i unplug the charger it shuts down. need...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 11, 2011 | Computers & Internet
I have a Acer aspire 5100 series BL51 notebook. It is running only when I kept the charging adopter attached. If I remove the adopter the message "Low Battery" shows on status bar after 5 min....
Hello
This is alarming stage of bad battery, you must replace the battery for better performance, other option is to replace the cells of battery (not recommended though).
Good luck
Dec 10, 2010 | Computers & Internet
HT1000. The low battery indacator beeps every 5 min with a fully charged battery.
With a fully charged battery and assuming that the battery is good. You need to check on/off switch, I often found the switch doesn't completly close and therefore, one side of switch is B+ but on other side the voltage is low that why low battery indicator keep beeping. Do that and see if it fix.
Radcom907
Sep 07, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Battery indicator keeps fluctuating to 4hrs to 6hrs back to 4hrs then 8hrs every 5 mins or so i have acer A0532H with windows 7
first of all let me ask how old is the battery, if it`s new-discharge the battery until pc shuts down itself because of low battery, remove the battery , unplug AC charger from laptop, wait for 5 minutes, then hold power button for 5 full seconds, wait another 5 minutes, then put battery and ac charger on , don`t turn on laptop yet, wait until battery indicator shows that battery fully charged, then remove AC charger, and turn on laptop. P.S. you can try this on old battery too, but usually worthless, because old batteries are not recognizable by system currectly ..
Mar 10, 2010 | Acer Aspire One AOA150-1457 Notebook
Cannot turn on
It could be. Most GPS's will not turn on if the battery power is too low (very flat battery). If you think it isthat try charging it via car or the mains power charger for a while (at least an hour). The charging light will not come on at first, then eventually light up to say it is charging.
Dec 01, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Bad battery or bad phone?
Looks like your phone is in 'Bootloader' mode, that's why it shows your bootloader info. Take your battery off for about 5-10 mins, and restart your phone.
Jun 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Battery charging problem
Where does a person buy a replacement battery
Dec 31, 2007 | Durabrand PDV-709
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
