Question about ASUS Eee 4G Notebook
Eee model number e4776. have had it for 8 months & it has cut off to a black screen now 3 times. it was just working..i have tried using just the power cord without the battery, ive tried having the power cord and the battery in...it is still not working...im now trying plugging in to a monitor turned monitor on first then the laptop my latop still shows a black screen. please help
SOURCE:
  • 45 Answers
SOURCE: Asus eee 901 will not start
Try this - open the laptop up and on the motherboard there should be a small round flat battery (bios/cmos) take this out and leave it out for atleast 20 minutes then put it back in and startup the laptop. Hope it helps, leave me a comment to let me know!
Posted on Aug 10, 2009
abrahambaby
  • 182 Answers
SOURCE: Asus Eee mini netbook monitor not working .
i think you have problem with driver software . better try by re-installing it again, else take to service center , because screens are the most complecated part
Posted on Feb 15, 2010
  • 20 Answers
SOURCE: My eee pc wont recognize that it is plugged in.
Usualy this is a battery fault.
If the laptop remains on ac mode without battery try to replace the battery.
Posted on Mar 10, 2010
hitul007
  • 11 Answers
SOURCE: my Eee pc monitor can't power on(dark),i tried to
when you start your pc then any beap is hear how many beaps are there
5 beaps - processor problem
3 beaps - ram problem
continues running - ram problem
2 beaps - hdd problem
no beaps - motherboard problem
firs you clean tour ram whith eraser.the try.
Posted on Jun 07, 2010
  • 902 Answers
SOURCE: my asus eee pc 900a
if you can boot past the bios as soon as it loads up hold down f9 it will boot into a recovery partion and re-install from scratch.
Posted on Mar 15, 2011
My tv cuts off 3 inches on the right side. There is a white line and then 3 inches of black screen. The color or brightness seems off too. Its a phillips 22PFL4505D/f7 manufactured Aug 2010
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts/
Apr 11, 2018 | Televison & Video
LG 65UH5500 TV just died while watching it. Screen gone black, no sound.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 16, 2017 | LG Televison & Video
Display not centered, no access to vertical scroll bar
That's because the LCD screen is going bad.
I would have said the screen Inverter, but the LCD screen uses LED's as a Backlight, and uses no screen Inverter.
http://www.screenaid.com/asus-eee-pc-701-laptop-lcd-screen-89-wsvga-glossy-led-p-36730.html
The above is just an example. Shop around for a better price, but advise make sure it is a reputable dealer. (I do NOT advertise for anybody)
1) http://pskillenrules.blogspot.com/2008/05/dismantling-eee-pc.html
(You can click on the photos to enlarge)
Found this recently. I feel number 2 adds to replacing the LCD screen, and number 3, also adds another idea for those who may be interested,
2) http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/78-asus-eeepc-model-4g-disassembly
Steps 1 through 10, THEN Steps 17 through 22. (You just want the LCD screen replace instructions)
3) http://www.youtube.com/watch?v=N8-BbOWVgXg
Regards,
joecoolvette
Jun 10, 2012 | ASUS Eee PC 701 Notebook
I have an Asus Eee PC Netbook that is 6 months old and I am having problems with. When I boot it up in normal mode the screen is extremely pixelated and everything runs so slow it is unusable. I have tried...
You may have a virus. Download Microsoft Essentials or better still Norton Antivirus. Run either of them and then download advanced system care , from IOBit.com it is a free version and very good at cleaning registry errors. If that doesn't fix it I shall be lost for words!
Jan 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I can not log in my router home page
1. Connect only a comptuer to the router using a ethernet cable to any one of the gray port on the router.
2. In the computer connected to the router, Click on start - > Run / Start scarch -> [type] CMD & hit enter.
3. In the black screen [Command prompt] type Start http://192.168.2.1 & press enter.
4. If still does not work.
5. In the black screen [Command prompt] type ipconfig & check what it the IP address under ethernet adapter local area connection,
6. It should be 192.18.2.x where x is a value from 2 to 254 & the default gateway should be 192.168.2.1.
7. If you get 169.254.xx.xx or any other numbers then try unpluggin the power from the router & pluggin the power back in after 30 sec.
8. Still the same numbers try pushing on the reset button at the rear of the router using a paper clip or pin for 10sec & release it after 10 sec once again unplug the power from the router wait 30 sec & plug back after 30 sec.
9. Again try step 3.
Thanks
Dec 27, 2010 | Computers & Internet
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
Dec 21, 2009 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Aug 15, 2009 | LG Prada KE850 Cellular Phone
New asus eee 900a linux, wireless light on, no internet connectio
Hi.....To fix this issue all you have to do is,Re- configure router still if its not working then
1)disable firewall on router and check..
2)disable anti-virus (Norton,Mcafee etc) & check
after this 2 steps (refresh network list connect to your network and check)
3)Confirm the model number & version of your router and check for firmware update.
May 31, 2009 | ASUS Computers & Internet
ASUS Eee 4G Notebook Logo
134 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
