Question about Honeywell Safes 2072 Digital Anti-Theft Safe - 1.06 cu. ft
My key is stuck in my safe.... I sprayed it with wd40 but it seems like a different problem than rust. the safe is pretty new and I know the code and can't lock it cause i can't get the key out??? I called the honeywell customer service and they had never heard of this problem.. Please help me!!!
3 Suggested Answers
BElectric
  • 1140 Answers
SOURCE: I own a Honeywell safe digital 1.06 cu #2072 when
If you are using the key, you don't need to enter a code. To open with the key only, please do the following:
1. Remove the key lock cover located beneath the digital keypad.
2. Insert one of the Emergency Override keys (2 included) into the bypass lock and turn to the left.
3. Pull the handle up and pull open the safe door.
I apologise if I have misunderstood the question. If you are unable to open the safe using either the key OR the code rather than the key AND the code, please post back and I will try to assist you further.
Regards,
BElectric
Posted on Dec 05, 2010
  • 10865 Answers
SOURCE: I have lost my key
hello strea..... take the safe to your local locksmith. be sure to have picture ID with you. J.
Posted on Mar 25, 2011
Stuck key??
If this has been sitting for a while the latching parts for return are probably gummy. Take off the bottom cover and spray some WD40 on the return mech,
DickyO
May 18, 2013 | Office Equipment & Supplies
Saw blade stuck
Do you have the exact model of your saw handy?
Also, try some PB Blaster instead of WD40, it works much better at freeing up rusted or stuck parts. Let it sit a couple of hours and spray it a few times
Jul 28, 2012 | Hitachi Saws
The two front doors locks, are not working, if I push them down it wont go down, if I try locking it with the key, it wont lock
Looks like you have a rusted/stuck up door locking mechanism. Open/remove your door cover finisher, use WD40 to loosen up the mechanism on your door lock. After spraying some lubricants, add some grease to the mechanism.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | 1991 Mitsubishi Montero
My 2005 won't turn off and has even started on it's own with no key in ignition...just statred happening last night. Had t disconnect battery to stop car. Seems like car doesn't realize the key is out!
We have had several issues with the ignition, had to have the locksmith save us at the gas pump with a stuck key and had problems starting many times. This is different but try WD40 sprayed directly into the key hole and work the key. With the cost of fuel it might be worth trying.
Apr 09, 2011 | 2005 Chevrolet Equinox
My key is stuck in the ignition of the 1997 zr2 blazer I just bought. How do I get it out?
Spray it with WD40 on the keyhole, the mechanism inside the keyhole are rusted.
Feb 24, 2011 | 1997 Chevrolet Blazer
I have a BMW316i Tourer (1992). There is a problem with the central locking. I can only lock the car via the boot or via the alarm. I am unable to open the drivers door at all and the key wont turn in it.
Try to spray some WD40 inside the lock cylinder through the key slot, sometimes when the key not in use for a long time it's getting rusted and stuck.
Aug 20, 2010 | 1992 BMW 3 Series
Freeze proof faucet dripping badly (hardly used, 6 yr old), bolt holding plastic handle seems pretty well rusted on. I'm trying toi figure out if there is a servicable washer that needs replacement.
It does have a serviceable washer. Use a 12" crescent wrench on the collar. unscrew the head and pull out. You may ALSO need to unscrew or "open" up the faucet to unscrew the threading in order to put the shaft out of the body. The spray and work the rust off with WD40.
Mar 20, 2010 | Plumbing
My key In my 03 H2 is stuck it won't turn back all
Go buy some WD40 and spray it inside the ignition and while your doing that try and move the steering wheel side to side and try pulling out the key. You might want a extra person to help you let then turn the wheel while your pulling on the key but first spray WD40 in there it wont hurt it plus it lubricates the key and ignition trust me this works I have done this tons of times.
PS you can buy WD40 at any auto parts store or even at a Wal-Mart.
Dec 18, 2009 | 2003 Hummer H2
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
Trunk lid
i think oiling the mechanism should proove usefull sounds like rust or simmilar
Nov 10, 2008 | 2003 Suzuki AN 400 Burgman
Honeywell Safes 2072 Digital Anti-Theft Safe - 1.06 cu. ft Logo
955 people viewed this question
Top Honeywell Home Security Experts
Marvin
Marvin
Mike
Jay Finke
Jay Finke
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
