Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
I have hard water and my dishwasher wont hardly clean at all, its about a 5year old unit
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Nov 06, 2010
Does this dishwasher Kenmore 13543 raise the water temp so the soap cleans correctly? We have hard water and even the best soap leaves a white film even adding rinse aide in my old BROKEN machine.
there is not much you can do with hard water as it is the minerals in the water that cause the problem
it is cheaper to let the washer heat the water as it only heats what it wants
Hard water comes from bores as most town water is put through osmosis filters that remove the minerals and produce the soft water
If you have a bore supply the seriously consider fitting a osmosis filter before the house as it will fix all sorts of problems found in the shower, hot water system , septic/sewerage and general health of the people in the house.
The initial cost will be outweighed by the cost savings from detergents and heating
Apr 07, 2015 | Dishwashers
Dishwasher gdwf16ov40ss
Might be one problem causing both symptoms. Do your "clean" dishes have a cloudy white film on them? If yes, you probably have hard water. The hard water deposits can clog your machine AND leave your dishes looking dirty. Here's is a link to a map showing the regions of hard water:
http://www.citriclean.net/why-citriclean/
Jan 04, 2014 | managemylife.com
How do I go about getting a manual for this dishwasher it is 2 years old. When washing glasses it has a film never looks clean. I have changed dishwasher soap and I am also using the other airdry. Not...
Manuals are usually available on line. The film could be from hard water. Check with local municapal authorities and see. If the local water hardness level above 9 then a water softener is required.
C
Dec 19, 2010 | Dishwashers
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Poor cleaning
I found a lot of stuff built up in the spray arms and replaced them...wife is happy again... :-)
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Apr 17, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwasher is 2 months old dishes do not come clean and leaves a white powery film on plactic cups
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Mar 02, 2010 | Kenmore 13743 Staimless Steel Built-in...
Dishes not getting clean. I use Jet Dry &
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 21, 2009 | Kenmore 24 in. 17039 Built-in Dishwasher
JDB6510 dishes have a cloudy film
check your screen or strainer in the bottom of the unit it is what filters the water to the pump if it has some trash in it or is plugged it will reuse the old water to rinse the dishes
Aug 22, 2009 | Dishwashers
Poor cleaning leaving deposits,dishes feel dirty
The problem for the spots is hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Aug 04, 2009 | Thermador DW44Z Built-in Dishwasher
Water is not reaching top spray arm.same problem about a year ago.took apart unit on bottom inside of dishwasher and removed build up;said it was because we have hard water.how can i fix it as it is of...
You're going to have to take the unit apart and clean the build-up again. Since you have hard water, it's recommeded that you use tablets instead of gel or liquid detergent. If you get a water softener, you'll have to use liquid. Good luck and sorry to hear about the hard water. I have the same thing here and it's no fun. Good luck :)
Jul 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
35 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
