Question about Dryers
I shut the door and it wont start up now light in on in side used it last night
  • 618 Answers
Door switch is bad.
Posted on Nov 04, 2010
I have a 1996 Dodge Stratus. The Dome light Won't shut off. It used to turn on and off with the door open and shut. what is going on? I have to move the switch to the driver's side to shut it off. The...
check for a door switch that the wire is touching the metal door frame and leaving the light on regardless of whether the door is open or shut.
Feb 20, 2015 | 1996 Dodge Stratus
Drove home last night and this morning my impala 2003 wont start
Security. Turn the key to run. Let it sit for ten minutes, off for thirty seconds. Then try to start. Do this three times for a relearn. Don't try to start.
Sep 07, 2014 | 2003 Chevrolet Impala
Charging system failure
i think you just need to get a new one
Oct 28, 2013 | Nissan Altima Cars & Trucks
How to disable alarm on 1999 dodge durango
Battery removal will not work. What will work is this: Use key to lock and then unlock driver's side door. I unclipped both horns at passenger side of engine compartment at front because they will go off while you are doing this procedure. I used this procedure last night after a rear passenger accidentally set of my alarm. I know this works! My vehicle is a 99' Durango.
Apr 30, 2012 | 1998 Dodge Durango
Yesterday i accidentally left my lights on all to day to find that my battery died. After I jumped it things were fine. Later last night, the interior lights in the front failed to work and now when I...
put the key in the door and unlock/holdover for 30 secs,then lock/hold over for 30 secs.then press/hold down the unlock button on the remote,you have juast reset the system........
Feb 18, 2011 | 2002 Volkswagen Jetta TDI
Turning off
check the supply or for any rat bites
Jun 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Intermitent alarm and unable to lock jag x type 03 from key fob
Hie kshep05,i'm having the same problem on my x type which i bought last week. it just started doing that yesterday and i am @ my wits end. Have you had a solution or diagnosis for your problem?
May 05, 2010 | 2003 Jaguar X-Type
We live in a cold state (MN) and this year though it hasn't been incredibly cold our 2000 Kia Sephia constantly freezes shut. The power door lock on the driver side won't move from the inside or the...
part of the problem with being in such a cold place is even tho its so cold there is still moisture in the air. if you door wont close or open, you need to check the latch out and make sure its not just bent. as for not being able to unlock you door. the latching system is connected to the lock and handle. if the latch wont move don't use wd-40 that will make it worse. you need to pull open the door panel and get it greased with a grease gun. wd-40 will not keep the parts moving in that kind of cold. if latch wont reset
when you get it open, it wont close. just grease it up. oh it would help if you get water guard for your windows. protect you parts from freezing. take care.
Feb 22, 2010 | 2000 Kia Sephia
We got our maytag 300 quiet series about 3 years ago from home depot. about a year ago the option buttons/lights on the right side went dead. It was out of warranty and still worked so i ignored it. Now...
Our Maytag dishwasher (an earlier model) quit too. Found that the door latch operates two micro-switches which supply power to the machine and one of the switches no longer made contact when operated. The switch pair and the plastic latch parts are sold as a package for about $15 on the internet. A number of lights in the door are held in place by a small colored lens for each light and the lenses have disintegrated leaving the lights to hang by the wires inside the door cavity. Plan to use contact cement to glue the lights in place. I don't know if this will help you, but it doesn't take long to open the door cavity. Make sure to remove power to the machine before opening it up.
Feb 05, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
I need to use my key to unlock the central locking of my car. It worked fine until last night when the drivers side lock will not open the car. I have to unlock the car using the passenger side door.Im...
i also have a MK5 golf tdi with cental locking problem the drivers door wont open from the fob but all the other doors will, i taken the car to a garage last week when it was pluged in to the computer it showed errors they cleared them it sem't to solve the problem now its started again ?
Jul 31, 2008 | 2005 Volkswagen Golf
Dryers Logo
Top Dryers Experts
