Question about Brother CS-8060 Computerized Sewing Machine
Inside tension discs
They appear to be on a spring and don't close all the way, therefore there is no tension on the lower thread. They are stuck in an open position like two cymbals that do not touch each other the little spring lever on the outside of the machine does not fully release. This has happened 2x before but somehow has resolved itself. Now it won't.
  • bacqua Jun 15, 2008
    thanks for such a detailed tutorial. will be working on this during the week.
  • Brother Master
  • 1,388 Answers
When the presser foot is in the raised position, the tension discs are relaxed by a mechanical lever near the needle arm.....this is quite normal.
When you say "lower thread" do you mean the needle thread ?
Once the presser foot is lowered to grip the fabric ready for sewing, the discs are again tensioned by way of a spring to give the variability required.
You may find you have thread or lint build up between the discs.
Try this generic tutorial for tension troubles and see how you get on.........it is possible, though unlikely that the presser foot lever has something broken, so try this first.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
inside tension discs - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jun 15, 2008
  • Hassy
    Hassy Jun 15, 2008
    Might I suggest in future you give your rating After the solution has been tried.......some considerable time was spent on creating this reply, and as our status relies on accurate ratings, whether it works well or not, there is now no possibility of altering it for better or worse.
  • 255 Answers
This is an extremely detailed and helpful explanation! May I suggest you make it into a tip?
Robbie/Lookingpast
Posted on Feb 10, 2010
Brother 1034d serger skipping stitches. Stitches are loose even when adjusting the tension.
It appears that there are two issues: skipping stitches, and, loose stitches. Let's deal with them individually but first some general points to check.
1. Change both needles for completely fresh ones out of the package. Make sure that they are inserted all the way up, this is very important. The right needle should appear longer than the left one. Make sure also that you are using the correct needles for your serger.
2. Use a good quality thread with very little stretch, almost no fuzzies, and in pastel colour. Dark thread ages quicker, therefore has a shorter shelf live. A good quality sewing machine thread is also acceptable.
3. Make sure that the tension dials are clean and free of lint or other debris.
4. Re-thread the serger in this order, keeping the presser foot in the down position at all times
a) Upper looper. Ensure that the thread is securely embedded inside the tension discs. Place the thread tail under the presser foot to 11:00 o'clock and place the presser foot down again
b) Lower looper. This is the difficult one to thread but make sure that all the thread guides are properly threaded as well as the upper looper elbow. Check that the thread is lodged between the tension discs. Once the lower looper eye is threaded, place the thread in front and over the upper looper and then under the presser foot to 11:00 o'clock and place the presser foot down again.
c) Right Needle. Thread the right needle path, again ensuring that the thread is between the tension discs. Place the thread tail under the presser foot to 11:00 o'clock and lower the presser foot.
d) Left Needle. Proceed as with left needle.
e) Double check that all tension dials have their respective threads embedded between the discs by pulling firmly up on each thread above the tension dials.
f) Check that the stitch length is set to between 2.5 and 3.0, differential to normal, blade position to middle, blade is engaged, and upper looper converter not in use.
g) Set tensions to recommended setting for 4-thread overlock.
g) Make a test stitch out. How is it? Still having the same issue/s?
If yes, continue with the items listed below, otherwise have a great time serging.
Skipping Stitches:
1. Check that the looper tips are smooth. Burrs will cause problems.
2. Check that the needles match the type of fabric being sewn.
Loose Stitches:
1. Double check threading.
2. Debris caught between tension discs will also manifest itself in loose stitches. Take an 8" X 6" piece of medium weight clean and lint free cotton fabric, fold it in half length-wise and pass the fold only firmly between the tension discs from top to bottom (with the presser foot up and no thread in the tension dials).
Re-thread and test stitch. How is it now?
Sep 30, 2014 | Sewing Machines
What can I do to wind my bobbin tighter
Make certain you are passing the thread through the tension for the bobbin winder when setting up to wind the bobbin. Check that tension assembly for anything that could be stuck in it, preventing the assembly from putting tension on your thread, such as another thread. Wiggle the disc on the assembly to make sure it isn't stuck. If none of that works, disassemble that assembly from the top of the machine (NOT the tension you use when threading to sew!) and see if the spring inside is broken. If it is, replace the spring if you can get it, or the whole assembly if you cannot.
Apr 28, 2012 | Brother LS-2125 Mechanical Sewing Machine
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
Brother CS-8060 Computerized Sewing Machine Logo
119 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
