Question about Garmin nuvi 1490T GPS Receiver
How do I get started with it? not much came with it in terms of how to set it up and use aside from how to mount. thanks.
  • 1,514 Answers
You can download the full manual with instructions on how to use it in Adobe Reader format from http://static.garmincdn.com/pumac/3130_OwnersManual.pdf
Posted on Nov 04, 2010
I have a Volvo XC 90 2004 and the upper engine mount needs to be replaced as it is broken please help. Thanks Bob
Remove the two bolts that hold the cross bar on each strut tower. 4 in total. Remove the bolt that goes through the mount you will need to hold the nut or bolt while turning the other. Put the cross bar aside and unbolt the mount. Remove and replace and reinstall the cross bar.
Apr 17, 2014 | Volvo XC90 Cars & Trucks
How do I remove the water pump on a 2007 Buick LaCrosse V6 3.8 l
Take off the PS pump and move it aside, without removing any PS lines. Either the PS pump or its mounting bracket may need to be loosened and set aside.
Oct 13, 2012 | 2007 Buick LaCrosse CXL Sedan
How y can change te motor mount
Put a jack under the oil pan. Use a piece of wood between jack and pan so you don't distort the oil pan. Raise the engine just enough to remove weight on the motor mount. Now you can remove the motor mount. If anything is in the way of mount removal, take it off and set aside. Once the new mount is on, you can use the jack to raise or lower engine for the through bolt (if it has one) to slide in the mount.
Post back if you still have a problem. Good luck.
Jun 19, 2012 | 2000 Plymouth Neon
Lg 40 tv shuts off
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_14_2012_2_38_47_pm.jpg
May 14, 2012 | Universal 40-42 Inch Flat Screen Panel...
Lg tv shuts off
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_14_2012_3_19_05_pm.jpg
Replacing a turn signal bulb....Baffled...Thanks
Please do not be baffled. To replace the turn signal bulb on Your car is quite simple, all You need to do is to get a screwdriver and follow the steps below:
  1. Open the hood and locate the mounting screws for the outboard marker-light assembly just above the light. Remove the screws with a Phillips screwdriver, then remove the assembly, setting it aside for now.
  2. Locate the two mounting screws on top of the turn-signal light assembly under the side-marker lens. Remove the two screws with a Phillips screwdriver, then set the screws aside. Slide the turn signal out and locate the socket on the back of the assembly.
  3. Rotate the bulb socket counterclockwise and pull the socket out of the assembly. Pull the bulb straight out of the socket and discard it. Install a new bulb into the socket, pushing it in until is seats. Position the socket back into the rear of the light assembly, turn it clockwise to lock it in place, then slide the assembly back into the front of the Jeep.
  4. Install the mounting bolts that secure the turn-signal light assembly, tightening the screws with a Phillips-head screwdriver. Position the side marker-light assembly to the side of the Jeep and install the retaining bolts.
  5. Tighten the retaining bolts for the side-marker lights with a Phillips screwdriver, then close the hood. Test the repair by turning the lights on and visually verify that the light is working..
Hope this helped. Thank You for using FixYa!!!
Jan 28, 2011 | 1998 Jeep Grand Cherokee
Is there any way to replace the serpentine belt on a 97 oldsmobile achieva without removing the engine mount
If its the 3.1 liter with the upper engine mount on the passenger side of the motor than no. You will need to remove the mount.
The good news is is its not that hard to do. Place a jack under the oil pan with a block of would between the jack and the oil pan and the trans pan as far to the passenger side as you can and still be able to touch both pans with the block of wood.
Jack up the motor just enough so that it just start to push up on the motor mount. Remove the bolts that hold it to the bracket on the engine. Remove the retainer for the cruise, if equipped, unplug the cruise and set aside. Remove the nut from the mount on top and the two bolts from inner fender.
Jack up the motor just enough to remove the mount.
You'll then be able to replace the belt.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Dec 15, 2010 | Oldsmobile Achieva Cars & Trucks
2005 Jeep Liberty overheats at idle but while in movement temp returns to normal.
Check to see if the fan on the radiator is working at idle.
Here's information on how to change the fan if needed:
Engine Cooling Fan Removal & Installation 2.4L Engine To Remove:
  1. Remove the coolant bottle and set aside.
  2. Remove the power steering reservoir and set aside.
  3. Disconnect the cooling fan connector.
  4. Remove the cooling fan mounting screws and the cooling fan.
To Install:
  1. Install the cooling fan and the mounting screws. Tighten to 50 in-lb (5.5 Nm).
  2. Connect the cooling fan connector.
  3. Install the power steering reservoir.
  4. Install the coolant bottle.
3.7L Engine To Remove:
NOTE: If the fan blade is bent, warped, cracked or damaged in any way, it must be replaced ONLY with a replacement fan blade. DO NOT attempt to repair a damaged fan blade.
NOTE: For 3.7L Heavy Duty/Max Cool/Trailer Tow cooling package, the viscous fan cannot be removed separate from the shroud. Both fan and shroud must be removed together.
  1. Disconnect battery negative cable.
  2. Using special tool #6958 spanner wrench and #8346 adapters, remove the viscous fan from the water pump.
  3. Gently lay fan into shroud.
  4. Disconnect the electrical connector for the electric fan, then disconnect connector from shroud.
  5. Remove the two fan shroud mounting bolts connecting the fan shroud to the radiator.
  6. Remove the shroud and fan from the vehicle.
To Install:
  1. Install fan shroud assembly into the vehicle. Tighten fan shroud to radiator bolts to 50 in-lb (5.5 Nm).
  2. Install shroud mounting bolts tighten bolts to 89 in-lb (10 Nm).
  3. Connect fan motor wire connector to harness connector, and attach connector to shroud.
  4. Connect negative battery cable.
  5. Start engine and check fan operation.
Aug 31, 2010 | 2005 Jeep Liberty
How do I change the o2 sensor
Hello, to change the O2 sensor follow this steps:
1. Set the parking brake if the engine has been run recently, let it cool for a few hours before you start.
2. Raise the vehicle with a hydraulic jack and place the jack stand under your trackers frame to supports its weight. Lower the hydraulic jack and set it aside.
3. Craw under the engine on the right hand side(drivers side) near the driver's door. Locate the catalytic converter, which is mounted in-line with the exhaust pipe.
4. Locate the oxygen sensor which is mounted in the exhaust pipe near the rear of the catalytic converter.
5. Remove the wiring harness connector from the oxygen sensor by squeezing in the connector tab with your finger while simultaneously pulling the connector from the sensor.
6. Remove the sensor from the exhaust pipe by turning it out with an adjustable wrench in a counter clockwise direction.
Thanks
Aug 25, 2010 | 2006 Chevrolet Equinox
How to replace Inside Rear View Mirror on 2000
Hello, to replace the rear mirror, try the following:
1. Roll the passenger side door window all the way down. Turn off the ignition and remove the keys.
2. Gently pry the window control panel from the arm rest with the pry tool or screwdriver starting at the bottom of the panel. Flip it over and unplug all the wire harness outlets from it. Set the panel aside.
3. Locate and remove the two panel door plugs near the arm rest concealing the two screws and remove the screws with the Phillips head screwdriver.
4. Remove the door panel retainer plugs along the edge of the door by pressing in the middle of the plug to unlock it and removing the plug.
5. Detach the mounting triangle from the upper inside door panel covering the side-view mirror.
6. Remove the door panel by lifting outward and then upward. Disconnect the speaker wire harness from the underside of the door panel and set the door panel aside.
7. Locate and disconnect the mirror wire harness.
8. Pull back the foam insulation from the inside panel covering the side-view mirror.
9. Unscrew the three mounting nuts from the mirror using the ratchet, extension and a socket. Do not drop the nuts into the door cavity.
10. Pry the mirror gently away from the outside of the door.
11. Install the new mirror and replace the mounting nuts on the mirror studs and tighten with the ratchet, socket, and extension. Plug the mirror wire harness back in. Replace the foam insulation. Replace the mounting triangle.
12. Replace the door panel by reversing the procedure. Start by plugging in the speaker wire first.
Thanks
Jul 26, 2010 | 2002 Pontiac Grand Prix
Garmin nuvi 1490T GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
