Question about Samsung DVD-V4600 DVD Player/VCR
Tray Wont open
Screen says "Load" but tray wont open
Samsung DVD-P341
  • 2 more comments
  • chris_may7 Nov 08, 2008
    Tray won't open when I press the Open button. It just says Load and does not open.
  • andrewwater Nov 09, 2008
    Power is on, start up screen is visable
  • Anonymous Dec 09, 2008
    DVD won't open, display says Load
  • OneDummy Dec 27, 2008
    I had the same problem. I determined that you don't put 2 CD's in tray at the same time!
    Problem Solver:
  • 10 Answers
Hello All. Well, I just finished troubleshooting the same problem of one of my customers units. At first I thought it was the tray contacts but they were good. What I noticed with the cover off and the shield for the laser removed...BE CAREFUL NOT TO BREAK IT TAKING IT OFF ANF DON"T LOOK AT THE LASER...that if I moved the DVD motor, the motor that turns the DVD...it has a rubber wheel on the shaft...that the tray would open. The trouble was intermittent but I also noticed that the wheel would move when pressing the OPen button. I therefore concluded that the motor somehow was in the circuit to open the tray. So, I took the motor out CAREFULLY and on the end opposite the wheel there are two small holes. These holes appear to be access holes for assembly and to hold the brush contacts away from whatever they use for a commutator. At first i was going to disassemble the motor but changed my mind. I have contact cleaner spray and some old Color Tuner Cleaner spray from the old days of mechanical TV tuners. I gave each hole a small shot of spray and turned the wheel. Careful not to contaminate the rubber on the wheel as it is what grips the DVD and pushes it against the white nylon bearing. Voila, the tray opens and closes and the Load display is no more. As I said, be careful. If you are unsure...let someone who understands this stuff do it. Ed
Posted on Dec 27, 2008
Exactly what I needed, thanks!
DVD-VR375 Disc Tray Won't Open
The disc ejection mechanism may have failed.
Apr 13, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Our Samsung DVD-H1080 DVD Player wont open, we've had it for a while, but the place where it opens is stuck, help??
Are you using the remote or touch button on case to eject tray?
Sometimes the top lid gets warped and prevents the tray from opening. Press eject and lift the front part of the lid at the same time.
Aug 17, 2010 | Samsung DVD-H1080 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
I cant open the dvd tray on my SamsungDVD-P241
turn off unplug ...turn upside down...this may dislodge it disk...gently shake...this may take a few tries
Dec 10, 2008 | Samsung DVD-P241 DVD Player
Dvd 4600
DVD tray will not open, the display comes up poen but the tray doesn't come out.
Jul 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
DVD tray WONT OPEN
unplug it and try it again, if that doesn't work see if theres a pin hole where you can push a paper clip in by the tray area.
Feb 26, 2008 | Toshiba SD-V394 DVD Player/VCR
Will not open the DVD tray.
if your dvd tray is not open you need a one inch pin or needle into hole..the hole right side .....then your dvd tray open
Feb 01, 2008 | Samsung DVD-HR720 (80 GB)
Original xbox wont load and tray wont open
Ouch, horrible problem.
Try these:
1. hold the eject button for 30 seconds
2. leave the xbox off for a few minutes
3.try a new outlet[may not have enough power to do anything]
4.get a new power cord
Hopefully this helps
Dec 28, 2007 | Microsoft Xbox Console
Samsung DVD-V5500 DVD tray intermittently wont open
Sometimes the loading belt can cause this problem or else have seen the tray in switch assy cause this as well.
May 23, 2007 | Samsung DVD-V5500 DVD Player/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
374 people viewed this question
Jerry Greenberg
Jerry Greenberg
