Back to:
Tags:
Telescopes
Generic problem for all Telescopes
Telescope knob
posted by Coach22 on Jun 13, 2008
The telescope knob used for adjusting the focus is comprised of the knob which connects via an allen screw to a threaded peice that connects to the telescope the knob portion I have but the piece of threaded screw is the one missing.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 13, 2008
Not Rated (0)
PaulMo
Rank:Wiz Wiz
Rating: 79%, 149 votes
Still not enough information, but taking a stab at it, I'll assume you mean the pinion rod that goes between the focus knobs, and engages a gear rack on the focuser. There are locations where they can be purchased, and you would need to provide the OD and pitch (teeth per radian) to match.
Try: http://www.pinionrod.com/ as a source.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on telescope knob:
I don't want to Accept this solution
Can you Help with these Telescopes problems?
Telescopes
I was given a BSA Optics telescope with no manual and I...
Meade 114EQDH4 (36 x 114mm) Telescope
i have the 497 controller and want to know what i need to...
Meade 8" LX90 LNT Schmidt Cassegrain...
I took my old motor drive apart to tighten some screws an...
Bausch and Lomb Professional 200 (200 x...
I have this telescope...With no idea howto use the lenses?...
Telescopes
Home accident: My Konus MotorMax-90 Telescope tipped over...
Loading problems.
Repair Service
Find Telescope Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
