Go to auto parts store and get the ford stereo remover tool and if your going with an after market stereo it would be wiser and easier to buy the stereo wiring instalation kit to...with the remover tool you stick on in the 2 holes on the left side of the stereo and the other in the holes in the right side holes just push them in firmly than not very hard but with steady pressure pull the left one to the left and right one to the right and than while still pulling them apart slowly start pulling stereo out
SOURCE: 2006 Ford Explorer "Oil Change Required" light is still on after changing the oil
IF YOU FIND THIS INFO USEFUL PLEASE RATE ME AS A FIXYA! THANKS
Oil Change Reset
A press of the OIL CHANGE RESET switch will allow you to
reset the oil life feature to 100% (or your Personalized Oil Reset
Percentage). After you have the oil changed, you must execute
the following procedure. Press the OIL CHANGE RESET switch
and hold for five seconds as the M/C counts down for five
seconds. After a successful reset the Message Center will display
“OIL LIFE RESET TO 100%.” If you have established a
Personalized Oil Reset Percentage, the display will show that
percentage instead of 100%. To ensure accurate oil life
indicators, perform this reset procedure only after an oil change.
Your Personalized Oil Reset Percentage allows you to establish a
smaller oil change interval than the manufacturer’s
recommended interval. To establish your Personalized Oil Reset
Percentage perform the following procedure:
1. Press and hold the OIL CHANGE RESET switch and press
the RESET switch while the display is still counting down
the 5 seconds to reset. The display will change to “START
OIL LIFE AT XXX%.”
2. Press the OIL CHANGE RESET switch until the displayed
percentage is the Personalized Oil Reset Percentage that you
desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%,
40% and 30%.
SOURCE: 2006 Ford Explorer XLT the Blower Fan only works on 4 and 3 Sp
Look under the dash on passenger side and just to the left of the blower motor housing you will see the 4WD control module.Remove the 2 screws holding the module and let it hang down and your resistors are behind this.Remove the 2 screws holding the resistors and remove.
Now I am assuming you have manual climate control and not electonic.
SOURCE: changing time on clock radio 1999 ford explorer xls
To set the hour, press and hold the CLK control and press SEEK. (Use arrows to increase or decrease hours). To set the minutes, press and hold the CLK control and press TUNE and use arrows.
This should work unless your vehicle has a separate clock module.(Other than the digital radio display).
