Question about Pioneer GM-X542 Car Audio Amplifier
SOUND CUTS OFF AT HIGH VOLUME AND POWER LIGHT FLASHED RED
HI...MY PROBLEM IS MY AMP WAS WORKING FINE AND STILL DOES AT VERY LOW VOLUME BUT WHEN YOU TURN IT UP THE SUBS CUT OFF AND THE POWER LIGHT FLASHES RED. PLEASE SOMEONE HELP ME AND TELL ME THE AMP ISN'T SHOT.
  • Anonymous Mar 30, 2009
    same as above
  • 631 Answers
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Posted on Jun 14, 2008
When i turn my volume up to a certain point the power light on my amp will blink off and on and the subs will cut off...what could be some possible solutions? is the amp not suppose to be tuned up? it...
Sounds like you are showing too low of an impedance load to the amp. The E1200 is only stable as low as 2 ohms. If your subs are wired to show lower than a 2 ohm load then the amp will go into protection mode as the volume or gains are turned up
Dec 23, 2010 | Jl Audio E1200 Car Audio Amplifier
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp not functioning right
Check the wires for a lose connection or corrosion. You may need a capacitor.
Basically, at low power the amplifier is not asking for a lot of power from the electrical system to power your sub woofer. For lack of a better term and probably the best way to explain it is. It uses up all the power in the wires leading to it at a high volume, and has to wait for more. Kind of like when someone squeezes a garden hose2_bing.gif when your trying to use it. That would be the high volume, starving the amplifier. The capacitor stores power in it to power the amp at high volume. 2 farads would probably be bulletproof on a single amplifier system, but 1 farad should work well enough. Or seek help from an expert on exactly what size capacitor you should use. If you find yourself saying: My amp cuts out.
If this assisted in solving your problem, please take the time to rate it. Thank you.
Oct 08, 2008 | Jl Audio 500/1 Car Audio Amplifier
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
Sony xm-1652z 1000 watt amp
a loose or corroded connection can cause this problem...do not overlook possible loose fuse holder...also look into remote control line...also check speaker line for a loose or shorted connection...a loose connection in any of these locations can cause a spike in the current drawn from the power supply... a bad speaker can play at low volume but short at high volume; if the flex wires from frame to cone on the speaker start to fail, it happens at high volume first, and sounds like a crackle, and gradually becomes present at lower levels; a voice coil can warp at high signal levels, causing it to short intermittently, in addition, you might check the cooling capability of the amp...i don't recall whether you have a fan on this amp...
Jan 11, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
1200 watt legacy amp not working right
your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Apr 14, 2007 | Pyle Dryver PLAD213 Car Audio Amplifier
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Car Audio & Video Logo
279 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
