Question about Craftsman 10" Table Saw
I just bought an used craftman tablesaw. The saw runs, but sound like a bearing problem, also the table needs some cleaning.
  • 7,733 Answers
Check if the blade is buckle.
Posted on Nov 04, 2010
Ok ,Your problem is the motor casing is broken and wedged in the motor,I cut a hole in the motor casing and pulled out the Broken plastic .And fixed mine.
Posted on Jun 22, 2012
Tablesaw start then kick the reset button out
The centrifugal switch inside the motor is bad or the run capacitor is bad.
Sep 24, 2014 | Craftsman Craftmans Contractor Series
Need view of craftsman tablesaw modelnumber 137.228010
go to searspartsdirect.com and with your moedl number you can download the schematic for this tool. I just looked at it. Let me know if you need more assistance.
Dec 27, 2011 | Craftsman 10" Table Saw
My tablesaw will no longer run. I plug it in and turn it on, the blade partially moves and I hear a humming sound
The motor is receiving power, and that is the humming noise.
The humming sound also says the motor is overheating and will burn out.
Turn saw off.
Use hand and manually rotate blade to see if it rolls free.
For example on my saw, the blade barely turned because a bearing was rusted.
I soaked the bearing in wd-40 and 3-in-one oil and salvaged it.
Look for oil ports on each end of motor, and on bearings.
Clean pulleys and belt that connect blade to motor.
If your blade rolls free, and the motor shaft moves freely, then the motor winding has gone bad, so replace motor.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on table saw or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 07, 2011 | Craftsman 10" Table Saw
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
Oct 20, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Craftman tablesaw manual for model 315274130
Here is where you can order a copy of your manual:
http://www.searspartsdirect.com/partsdirect/part-number/Craftsman-Parts/Saw-Parts/983000571/0009/315/Model-315274130/0247/0744600?keySuffixId=NA&productTypeId=x&searchModelNumber=315274130&subCompDesc=Cabinet%20assy&brandDesc=CRAFTSMAN&modelDesc=TABLE-SAW&blt=11
Kelly
Sep 24, 2010 | Garden
What's the smart way to remove the motor for
i wouldn,t remove unless you think needs new bearings or cannot get to the brushes, turn upside down if has base cover remove and blow out best you can be sure no water in air line.
Jan 05, 2010 | Bosch Electric Table Saws
I need a table saw motor model rm871 where can i go to get it?
Sears.com would be the only place that I know of, I also think that the motor number has changed,
Oct 02, 2009 | Saws
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Table saw blades maintenance
You can clean your blades while they're on the saw, but if you do make sure to disconnect the power. An easier method is to clean the blade when you're removing them to have them sharpened. The buildup can be removed using a furniture-cleaner known as buildup remover. Apply the cleaner directly onto the blade, and use an old toothbrush to scrub away the buildup. For stubborn buildup, follow up with some cleaner and fine steel-wool.
Aug 27, 2008 | Jet 708315BTC/JBTS - 10BT - 3 10 Benchtop...
Craftsman 10" Table Saw Logo
111 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Tim Venetis
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
