Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
2 problems model PSS29NHMC WW serial NA409439 some vegies are freezing in the fresh produce drawer water does not always come out
    Master:
  • 555 Answers
Do your vegetable keeper drawers have humidity controls?
Posted on Jun 13, 2008
    Champion:
  • 214 Answers
Hi, your refrigerator is having an autodefrost mechanism. It works just like, after a predetermined intervel one heater element fitted inside the freezer compartment get heated up and all the ice formed is melted out. Again after this the compressor starts working. In your case the heater element circuit is not working. Thats why the vegs get freezed. Its not advisable to service it user level becoz opening the freezer compartment is not that easy. So please contract a fridge mechanic to carry out the repair.
thank you
Posted on Jun 23, 2008
    Master:
  • 848 Answers
There exists some thermostat problem in your refrigerator replace it
  • 1,879 Answers
The temperature in your refrigerator should be 34°- 40°F (1°-4°C). Pathogenic (disease-carrying) bacteria thrive above 40°F. Below 40°F, spoilage bacteria can still grow on foods - affecting their taste and smell - but they're not generally harmful. If the temperature is too low, vegetables can freeze
Formation of water
If your refer has a watering device on the outside of the door then it could be that the resevour is cracked and leaking into the refer. It is usually behind the meat drawer ot somewhere in the lower part of the refer. If you do not have a water dispenser but an ice maker then it is posible that the ice maker is leaking. but that is not that common. There is one more possibility that it is just condensation from the lettuce crisper or the drawers below where fresh vegies would be. If that is turned up too high or low then condnsation can accur and then leak to the bottom of the refer. Check these things out. and you can check you owners manual if you have one. you can download a manual for free online also for your brand and model #. they will have a trouble shooting section for this comon problem. Good Luck
Apr 10, 2012 | Whirlpool Refrigerators
My refrigerator Kenmore model 795 77563600 freezes up the vegies on the left side drawerand werever I store on top of that drawer. What can it's wrong with it?
Your refrigerator as cooling tubes that allows the cold air or the freezer to go to the refrierator side. If one becomes blocked with frost all the cold air is then forced to route through the other cooling tube. And that what it sounds like is happening to you.
Jan 04, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We just purchased the Frigidaire FGHC2378LP and hooked up the water line and it worked, no problem. Then we unhooked the water supply from the water shut off valve for 3 days and hooked it back up and now...
Sounds like its frozen, is why you arent getting water unfortunately until you fix temp problem or unplug it to thaw it, its probably not going to work.
Sean
Mar 27, 2011 | Frigidaire FGHC2378L Side by Side...
The lettuce and squash in the fresh produce drawer seems to have frozen. This is first time for this problem. (We have owed the condo about two months.) Are there separate settings for that drawer?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 16, 2010 | Refrigerators
MODEL # 59673504203 DRAWER IS ALWAYS FREEZING EVERYTHING IN IT. NOW NO ICE IS BEING PRODUCED
I had the same problem. I pulled the drawer all the way out. In the back is a vent flap. Ice had formed on it keeping it open. I chipped off the ice so the flap can move. This stopped the freezing veggies.
My ice maker stopped working. It was suggested I change the water filter as it may be clogged preventing water moving to the ice maker. As I am getting a new refrigerator I all not be buying a new filter.
This message is little late for the original poster but may help someone else.
Aug 04, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Purchased in 2002 and is starting to freeze in the
Check the back of the fruit and vegi drawers. If theres a slot for an intake port try closeing it (if adjustable) Check thermostat setting for fridge and adjust to a lower setting.
Finally make sure door closes and seals closed, clean gasket with mixture of white vinegar and water (1 cup vinegar to 1 gallon warm water). If this fails internal thermostat may need replacing.
Dec 17, 2009 | Amana ARS2464B Side by Side Refrigerator
My GE Model PSS25MGNAWW Artica Profile Refridgerator has begun freezing the contents of the bottom Sealed Pan and Fresh Produce Drawers. Put setting up to 2 and Chill Dial to Cold (left) but temp is stayng...
Freezing in cripsersG.E artica:
Models Affected: All 23 25 27 and 29 cubic foot electronic side-by-side refrigerator units with plastic Liners manufactured in 2001 or later. This includes all Profile- (Arctica and Eterna") models Consumers have called with reports of freezing in the Vegetable (middle) pan or the CustomCool M (bottom) pan , frozen water tank or frozen water filter.Freezing in the pans , a frozen water tank or a frozen water filter is caused by excessive airflow from the vents in the tower.
To eliminate these freezing issues , install kit WR49X10045. Follow the instructions included in the kit.
Damper door broken G.E artica:
Affects all 2001 models produced with "M" as the eight letters in the model i.e.: PSS25SGM with serial date code LA4 , MA4 , RA4 , SA4 , TA4 , VA4 , ZA4 & AD4. Freezing happens when damper door breaks leaving the unit with no control over the very cold air entering fresh food compartment from the freezer.
Replace damper door assy , with new damper door kit WR17X11508.
To verify the damper door is broken , remove the light shield and rear light bulb from the top of the refrigerator. Enter the factory diagnostic mode by pushing all four temperature control buttons at the same time. Perform damper motor test (FZ 1 , FF 0). Press any other button i.e. Custom cool or filter reset to start damper test cycle. Shine flashlight through right hand side opening of light assembly to view movement of damper door. To exit test mode (FZ 1 , FF 6). lf damper door assembly needs to be replaced , pull top two shelves out 2 ". Pull rear tower assembly slightly forward with both hands, move to the left and the right to expose the two screws that secure the duct assembly , also remove both screws that secure the duct to the ceiling. Replace with new damper motor assembly WR17X11508.
Dec 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to stop water from pooling on the middle of shelves. The water seems to come from nowhere. Also, what is the best setting for the humidity sliders on the fruit and vegetable drawers.
If it is a static appliance with a ventilator this can happen at colder settings you can try to increase the setting so the condensation can be decreased.That water is the condesed water which comes from your food.
Actually these has a very small impact if you do not have %100 sealed drawer.If you have fresh vegies it should be totatlly closed so the humidty levels increase in the drawer so the freshness.
Sep 26, 2009 | Maytag Refrigerators
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
331 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
