Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi 725r 31cc
Motor will not stay running unless I keep pressing the primer bulb. As soon as I stop pressing the bulb the engine dies. It seems to be getting enough gas as gas is dripping out around the carburator area.
  • 2 more comments
  • dragonnovice Jul 24, 2008
    gas is leaking from the rotten plastic bulb. where to buy the primer bulb for ryobi 725r?
  • Anonymous Aug 10, 2008
  • Anonymous Aug 19, 2008
    will start but will not stay fired up stalls after a couple of minutes
  • lulawilson Sep 30, 2008
    I have the same problem. After I start the trimmer, I push the blue switch back and hold it there for a few seconds, it will continue to run as long as I do not turn the trimmer upside down. Need a solution.
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Posted on Jul 03, 2009
Hey! had the same problem w/a trimmer not used for 2 yrs. Tried the bulb replacement since I cound see air in the fuel lines. Solved the problem! (Saved the hassle + $$$ of replacing the carb). Thanks a big bunch! Ryobi model 767r 16" 31cc This would probably work on other engines using bulb primer.
Bob, Colorado, 7/03/08
Posted on Jul 03, 2008
Remmbered you have to have good compression 110 psi and good presser in the block or vacuum.
Posted on Oct 10, 2008
The primer bulb has a small air leak or rupture. You will need to replace the primer ball assembly
Posted on Jun 18, 2008
Is the primer bulb necessary?
I dont think you should do that since the primer bulb is what gives gas to the carb, on most models.
Jul 28, 2012 | Ryobi Garden
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Ryobi 725r leaks gas from air filter and will cut out after starting up
This is a problem with most ryobi tools. From what i've read over time the gas lines shrink and need to be replaced. You'll need to replace both the lines coming from the carb to engine and the one connecting to your primer bulb. I hear there is a kit that contains both the primer bulb and fuel lines for this exact problem.
Apr 21, 2010 | Ryobi Garden
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Aug 01, 2009 | Ryobi Garden
if these parts were deteriorated then the carby diaphrams will be hard therefore they wont pump fuel.
Jul 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Engine won't run unless primer bulb is being pumped
I have the same problem and may have a solution. I looked at the primer pump and it was cracked letting air into the system. When I pumped it my finger was over the crack and it worked fine. When I stopped the crack was able to **** air again. Take a look.
Jun 20, 2009 | Boating
I need to know how the fuel lines should be connected for Ryobi 725r? There are three.
The line from the fuel tank that has the filter on it goes directly to the carburetor below the primer bulb. One line comes from the carburetor to the primer bulb. The other line goes from the primer bulb to the fuel tank. Primer bulb can be pressed to determine which side is pulling fuel (line from carb) and which is pushing (line to fuel tank).
May 15, 2009 | Garden
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
2,562 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
