Question about GTO Mighty Mule Automatic Gate Opener For Single Swing Gates Up To 18 Ft Or 85
I have a mighty mule automatic gate opener 352. I left the arm turned upside down after installation and it rained in it. The gate stopped working, and it clearly states that i have voided any warranty. I am currently drying out the circuit board, but when i attempeted to reconnect the battery, i crossed the wires and put the negative wire on the positive battery end. I have also disconnected the red wire and the black wire under the board, when i set the board out to air dry. i am not sure which way the wires go back and i cannot find a circuit board diagram online. However, i dont know if i have already fried the board by connecting the battery up backwards. what can i do?
5 Suggested Answers
  • 68 Answers
SOURCE: How to use 2 button remote for two mighty mule gate openers
Chamberlain products do not support a 318Mhz frequency that gto uses, so that remote will not work unless you get a liftmaster receiver or any other one that it uses.
Posted on Aug 10, 2010
freetek
  • 5569 Answers
SOURCE: I have a mighty mule
If you are going to DIY, I would suggest checking to find if you have a Johnstone Supply branch in your area, removing the motor going to them with it. They carry a huge range of motors and often their price is less than half what a dealer might charge. They appeal to tradespeople but I have never been turned away and have saved hundreds of $ over the years with them.
You might find your motor in their online catalog:
Johnstone Supply
Posted on Jan 04, 2011
SOURCE: Mighty Mule 500 motor repair
Try Mouser.com part # P6KE16CA 36 cents a piece.
Posted on Jul 09, 2012
jasonamar
SOURCE: is the GTO-Mighty Mule gate opener compaticle with 2012 Chevrolet Silverado Universal homelink?
Its kinda hard but if you follow the info in the owners manual for your truck it works. It is not rolling code like a gargae door this is a dip switch on or off .
Posted on Aug 02, 2012
What is the u shaped component on the rev.counter card called? Where can i purchase this component?
  1. Mighty Mule Parts - Gate Opener Parts & Accessories‎
    Adwww.mightymule.com/Accessories‎Cable Gate Lock
  2. Driveway Alarms
  3. Gate Opener Kits
  4. Where to Purchase
Search Results
    Mighty Mule Store ' Genuine Mighty Mule replacement parts
    www.mightymulestore.com/Mighty-Mule-Gate-Opener...Parts-s/21.htm
    Genuine Mighty Mule Replacement Parts. Choose a Product Category. Mighty MuleFM200 Automatic Gate Openers · Mighty Mule FM350 and FM352 Gate ...‎Mighty Mule 500 Parts - ‎FM350 or FM352 - ‎MM600
    Mighty Mule 500 Parts ' Shop Accessories and parts for the ...
Jan 01, 2016 | GTO Mighty Mule Automatic Gate Opener For...
Why is my mighty mule FM500 gate opener opening by itself?
Cathie,
Thank you for using GTO Products. If the gate opener appears to be opening by itself, then it's receiving an input from an accessory such as a transmitter, keypad, push button, exit wand, photo beam, loop detector, telephone entry system, etc.
By disconnecting these devices and reconnecting them back to the system one at a time, we can use a process of elimination to determine which device is causing the problem.
If you still need assistance, please call our tech support from the gate so we can help you troubleshoot. You can contact us at 800-543-1236 Monday - Friday from 8:00 AM to 6:50 PM EST
Technical Support
GTO Access Systems, LLC
Jun 29, 2014 | GTO Mighty Mule Automatic Gate Opener For...
Is the GTO-Mighty Mule gate opener compaticle with 2012 Chevrolet Silverado Universal homelink?
Jun 07, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Jan 12, 2012 | GTO Mighty Mule Automatic Gate Opener For...
Is there a cluch in sliding gate motor
There is no internal clutch for the linear actuator gate motors... only a mechanical limit switch(micro-switch) which is only relevant in the arm-retracting motion, and a sight-wheel & eye which is used for electronic limits in the arm-extending motion.
Oct 16, 2010 | GTO Mighty Mule Automatic Gate Opener For...
Mighty mule gate opener motor burned up after 2 years
Did you ever find a motor to fix the gate opener? I am looking for the same motor and would appreciate any help you can offer
Mar 27, 2010 | GTO Mighty Mule Automatic Gate Opener For...
I have a mighty mule gate opener model number 352 and the cycles only open and close two inches. How can I have it properly open
Check the STALL FORCE setting on BOTH openers, check for gate obstructions broken gate hardware. OR your limit settings have been erased, but if none are the problem that you have a broken REV COUNTER which is inside the arm
Oct 18, 2009 | Gates Deer Fence: Mighty Mule Driveway...
Gate open and beeping,it will not close
Well if your board is getting power and the power supply is ok, but when you try to activate the opener, and do not get a response, than you have a faulty board, im Guessing you have a GTO 1000, Mighty Mule 700, or Mighty Mule FM500 series
Mar 13, 2009 | GTO Inc. / Mighty Mule Gate Opener Battery...
GTO Mighty Mule Automatic Gate Opener For Single Swing Gates Up To 18 Ft Or 85 Logo
112 people viewed this question
Top GTO Home Security Experts
Rob Villi
Level 1 Expert
Tom Chichester
Mai Lor
Are you a GTO Home Security Expert? Answer questions, earn points and help others
