Question about LG WM-2277HW Front Load Washer
2007 LG Tromm washing machine Washer won't stop filling, even when disconnected from power supply It's just the cold water, like a switch is left open hot is okay
  • 1462 Answers
SOURCE: LG WFT1022TP top loader washing machine
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off. the things to look for are: gunge in the air chamber split in the pipe. faulty pressure stat to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
Posted on Apr 02, 2007
particleman
  • 9 Answers
SOURCE: No hot water entering
1. Make sure water comes out of the hot water hose into a bucket.
2. Check to make sure the solenoid valve is working. The buzzing is the 60Hz on the coil and can make a lot of noise if valve does not operate properly. Try blowing into the hot water port. If the solenoid is functioning properly air will move freely, if not its stuck.
Posted on Jan 10, 2008
johnychel
  • 796 Answers
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Posted on Mar 23, 2008
drsn
  • 42 Answers
SOURCE: LG Tromm - WM2688HNM - Detergent dispenser full of water & some detergent after wash.
sounds like you have calcium build up, this happens alot with LG's. need to take out the dispenser and clean the calcium with industrial lime away, that only works good for me, but others will do, also use a sharp object, like a ice pick or finishing nail, to scrape off any left over hard residue.
the calcium will clog all the holes in the dispenser.
if this doesn't solve your problem, then there is one thing left
just email me and ill give you the other solution.....
drsn777@hotmail.com
dave
Posted on Dec 12, 2008
SOURCE: Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Posted on Jan 05, 2009
What does it mean when my lg tromm WM2487HRM front load washer slowly fills the tub with water when the washer is off?
most likely water fill valve is defective and leaking. hot water or cold water? replace which ever is leaking
May 21, 2016 | LG Washing Machines
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
What can cause a washer to not fill with cold water during the wash cycle?
well it would seem these are the possibilities:
1. cold water not turned on
2. hose kinked
3. inlet valves not working
4. wiring issue
5. control board issue
oh and plugged inlet fill filter
good luck
Sep 02, 2015 | LG Washing Machines
Wont rinse
As rinse cycles are cold fills you may have a problem with the cold water supply valve. If you put your machine on a cold wash only and it does the same thing this problem should show up while filling and lead you in the right direction for repairing it.
Dec 27, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error no water supply
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 28, 2011 | LG WM2688HWM TROMM SteamWasher
LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Jul 12, 2009 | LG Washing Machines
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
May 19, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
626 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
