USB flash drive is not detected by my computer.Please give me a solution.
    Brigadier General:
  • 10,406 Answers
Restart your computer, then try connecting to a different USB port on your computer.
Try connecting it to a different computer.
If it still is not detected, it is "dead". Spend $10 to $20 to buy a 2GB to 8GB replacement.
Posted on Nov 04, 2010
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I HAVE MY PNY 4GB MICRO PEN DRIVE.....AS NOW IT GOT CORRUPTED.... IT CAN'T GET DETECTED BY ANY OF COMPUTER AND LAPTOPS ......SO PLEASE GUIDE ME THROUGH THIS PROBLEM..IS THERE ANY SERVICE CENTER IN...
SaveMyUsb.com can recover data from most damaged faulty and corrupt flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 28, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Flash drive will not read?
Have you been able to get it to work on another computer? Have you formatted it? Check how many drives you have on your computer (i.e. c: d: e:) if you have many, then you may need to give your Flash Drive a new drive letter, see the following link: http://ezinearticles.com/?Flash-Drive-Not-Detected?-Solution-is-Here&id=1526594
Cheers.
Jul 09, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Not detecting to any pc.
Manthesh Bhai
Please try in another PC if this does nto work then your USB is faulty please get a replacement
Feb 10, 2010 | Transcend (589307) Media
I'm a tech IDIOT - I bought an 8GB flash drive to back up ''my documents'', but don't know how to DO it. I've put the flash drive into an available USB port...
Please follow the simple steps to copy the data from your computer.
1. Plug in the flash drive to the USB port available.
2. Wait for a while til the system detects the drive and it will show the detection details on the extreme right side of the task bar.
3. Once the computer has detected the USB/Flash drive you can do a double click on the MY COMPUTER icon on the desktop where it will show you th external drive as a Removable drive. Once confirmed you can close the page.
4. Then you need to go inside My documents by doing a double click on it.
5. Select all the documents by either doing a CTRL+ A or you can select the documents one by one by pressing CTRL and with the mouse just single click on a document.
6. Then after you have higlighted the articles to be moved please do a right click with the help of mouse cursor, where it will give you a option SEND TO and then you will have the option of Removable drive over there.
7. Just select the removable drive and all the data will be copied with in the next few mins.
Your system will tell you the time it wil take in order to send the complete data.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Jan 06, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Usb not detected
usb may be affected by virus, formate the usb and use. or check the driver is whether activated or not
May 21, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Kingston DT1000 pendrive was not detected in computer
hey my 8gb kingston pen drive is not detecting at any that is out of warranty any tricks to make it work. i was tried all my level best but that is not detecting............. so any chance get that back
Feb 04, 2009 | Transcend (589307) Media
My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Nov 24, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
PNY 4G USB 2.00 Flash Drive
Solution:
i) try connecting it on the USB port present at backside or back panel of your computer tower, sometimes USB port present on the frontel panel of your computer might malfunctione or not working properly........
Nov 20, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
