Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility. Have a nice day and do not forget to rate please...!
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy If it doesn't answer, it's not set to AUTO RECEIVE If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
ALL FAX MACHINES ARE ANALOG DEVICES AND WILL NOT WORK RELIABLY ON A DIGITAL SYSTEM OR A COMPUTER....Magic Jack, Vonage, etc. are DIGITAL PHONE SYSTEMS. Don't believe what the Vendor tells you. They are for designed for VOICE GRADE PHONE CALLS ONLY.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Make sure your phone lin is plugged in the jack on the machine that says LINE not the jack that says TEL or PHONE. I have seen this before. the unit gets a dial tone and can send but will not answer.
Hope this helps
if your fax is on a dedicated fax line, make sure your display says "fax only" or "auto". if not on a dedicated line, you'll have to give more info on what kind of hook up you have. in other words, is there an answering machine hooked inline, etc.
Hello, I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
You can hook a fax to any standard phone line. That is what they are designed for. The only issue is if you share the fax with your telephone, you will need to set the machine up to receive the fax before you answer the phone.
What you are experiencing is line loss. What happens when you run a phone line to a fax with several items attaches is you lose varying signal strengths. Seems like you should be able to say, ahh a phone line is a phone line. But you are losing one of or all of 3 things. Either you phone line voltage is low, if its not low, your phone line current is low or you are experiencing Decibel loss. All those have to be correct in order for the machines circuitry to pick up the call. It's different dialing out, it just flips a relay to the line, just like you do when you lift your receiver. On receive mode, It is the impulse from the incoming line that has to be correct to turn on the relay. So, not enough voltage, current or ampllitude. no activation of the components in receive mode. I know it's not easy, or cheap, but when fax is important, a dedicated line is always the way to go.
