Question about ASUS P4P800-MX Motherboard
Asus pap800s x
The board is an s-x, but i bought a new power supply. Board is stripped, with power on just green light. I pulled cpu out and powered up but still no fans.
  • 84 Answers
Check the hard disk if its properly connected, then remove the cmos battery for 30 minutes then put it back, try to boot to cmos/bios then check if its reading the hard disk.
:)allen
Posted on Jun 27, 2008
  • A Vallescas Jul 09, 2008
    check your fan it might be deffective
  • A Vallescas Jul 21, 2008
    maybe the fan is defective, try to re insert all the power connections in the mother board
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I had an asus P4S800 MX motherboard and power supply and I think I have everything setup the way it is supposed to be. The power light is on the motherboard, the monitor and keyboard are plugged in, and...
hello brother..you must replace your motherboard! the problem with this asus series led consumers to panic. P4s800-mx boards are sensitive on power surges..this boards i think did'nt pass from power test tolerance. they can't withstand abrubt power changes. even the green light onboard indicates power presense and the proccessor's fan is working, believe me.that is already totally dead, even if you try to change the power supply it will not work either unlike asus's early version like p4s533mx, p4b533, p4v533 etc...are more reliable on power changes.this is the downfall of p4s800mx..but if want to still revive it, you must have a good skills on soldering small components..p4s800mx regulators sucks and even you replace it, it will bear the same problem.i only have the chance to post this solution because i noticed that anyone seems dont have a concrete solution regarding this..i already dumped 300 units of this boards. because there is no posibilities to elongate the life of this boards you are very lucky if you still have this boards(just try to use HQ voltage regulator to protect it.) the thing is, the tiny capacitors lied accross the processor at the solder side is always malfunctioning and the power regulators(component side) always changing in value that dont sychronizing to the power needed by the board...please pass my solutions to our members for them to understand. i am a filipino and we have a wide posibilities of solving this problems we love technology and technologies are just made by us we all have the solutions.
thanks brothers.....
you can contact me on my email: almond_expert@yahoo.com
Feb 28, 2009 | ASUS P4S800-MX Motherboard
No video
Go to the Asus website and download the drivers for this board. It's most likely that it did not come with drivers installed. Hopefully this will fix the problem. Good luck.
Dec 23, 2008 | ASUS P4V8X-MX Motherboard
The cpu not on
You wil have to give me more details please
Oct 17, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Power supply
I think your problem is not with the power supply, its the hdd or memory thats causing the problem. try to check the cables, and re insert the memory then start up your pc again.
allen
Jun 12, 2008 | ASUS P4P800-MX Motherboard
No Output to monitor, no beeps, fans all OK
Hi karanda,
The green led on the board shows green letting you know there is power to the borad.
Does your GFX card have dual outputs? Try plugging into the other output.
If your monitor light goes from green to amber than your PCI-E is not putting out signal. Pull & re-seat video card.
Did you check Asus to see if your CPU is supported & check what bios version you may need to run CPU?
Chcek here: Check what your M2M-E supports.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Your board only supports these two CPU's
Phenom 9500 (HD9500WCJ4BGD),2.2GHz,95W,SocketAM2+,Quad-Core
Phenom 9600 (HD9600WCJ4BGD),2.3GHz,95W,SocketAM2+,Quad-Core
You need Bios version 0802 in order to run the above CPU's.
Good Luck & kind regards!
Mar 10, 2008 | ASUS M2N-E Motherboard
No respons at all !
I think your power supply cables is not able to start your B-board if your power supply is working properly then check mother board jack where you insert your power supply plug in M-board. Then you have to change or repair that jack where you insert power supply wire in M-board. With best regards M. Khalid Shaikh from Pakistan Mobile: +92-332-2631983
Sep 19, 2006 | Intel Desktop Board D845BGSE Motherboard
ASUS P4P800-MX Motherboard Logo
210 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
