Question about Cannon Cameras
Just bought camera second hand; zoom lens "bounces" in and out; battery indication low; camera has three different brand batteries. Any suggestions? Model is Powershot S5is.
  • 10,865 Answers
Hello. Remove the batteries and get all new and all of the same brand. Be sure you get the proper battery for your camera. Go to a camera shop to be sure. BEFORE you put the new batteries in do this. Clean the battery contacts within the camera with the eraser end of a common pencil. Joe
Posted on Nov 04, 2010
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
My camera worked fine for 3 years, when suddenly .... when i'm zooming fast (zoom button pushed down) camera switches of. If i'm zooming slowly everything is ok. Some master said that zoom lens motor...
I would say to check the batteries and their connecting surfaces plus the contacts in the battery compartment. With bad connections on the batteries, when the camera zooms slowly it does not use much power. When zooming fast it uses more power (current) and if the batteries are making a poor contact the camera will shut down due to low volts. Check that first before spending big money. If you are using Duracell batteries, they have a short + pip end which some devices will not work with them due to poor conection. Compair a duracell battery with another brand. see the difference on the + end.
Aug 04, 2010 | Canon PowerShot S3 IS Digital Camera
Lens not extending
You have a lens problem. Sure it can be fixed but be sure to get an estimate first.
Aug 24, 2009 | Samsung Digimax S73 Digital Camera
Lens goes in and out three times when turning on or shutin off.
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is recommended.
Jun 15, 2009 | Sony Cameras
Camera immediately turns off after being turned on
I have owned three Kodak cameras, the last and recent one being the M1063. They all three developed the same problem within two months of ownership....."zoom lens will move in or out depending on original position(gets stuck in out position), and camera beeps, then turns off."
It was always sand/dirt/dust in the zoom section.
Hold the camera in your right hand, as if you are going to take a picture and gently tap the left side of camera against the hard, lower part of your palm.
You might have to do it a couple of times and you might have to be a little more than gentle. Just don't bang it hard directly on the LCD screen, just the left edge.
It always works for me. Good luck.
Aug 03, 2008 | Cameras
Low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Jun 17, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Difference between the D-460 and the D-450 Zoom digital camera
The D-460 Zoom shares the following features with the D-450 Zoom: •1.3 megapixel resolution - 1280 x 960 pixels •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •2x digital telephoto mode •3x image magnification inspection mode •Sequence mode: Up to 10 images at 2 frames per second intervals (SQ mode only) •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self timer •8 MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings (125, 250, 500) •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-460 Zoom has the following functions and features: •Industry standard icons for button labels and operation menus •Easy to use jog dial and button design allows easy menu navigation •2 compression ratios are now selectable in SQ mode •Selectable Sharpness: Normal or Soft •Selectable Memory Mode Setting: Reset camera settings at power-off or Retain all camera settings •2 Olympus brand CR-3V long life lithium batteries included. Provides 20-30 times the power/life of alkaline batteries
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Cameras Logo
Top Cannon Cameras Experts
Computer Links
Harrie
D. E. Hev
Are you a Cannon Camera Expert? Answer questions, earn points and help others
