Question about Epson Office Equipment & Supplies
Error code: 00010004 Carriage motor encoder check error ?
Inky
  • 691 Answers
SOURCE: Hey All
This error relates to the encoder strip for the carriage motor. The encoder strip is like a piece of graph paper and the head has an eye that reads how many lines it passes. This is so the machine know exactly where the head is at any point.
The error means that the machine is not correctly reading the encoder impulses. This could be because the encoder has broken, the eye has gone blind or a circuit board or cable has become faulty. It could be that if you have done maintenance that one of the connectors has been replaced with incorrect polarity.
Check the basics first:
  • Is the encoder attached and correctly routed through the optical sensor
  • Is the encoder strip clean - if there is a splodge on it, this will result in error
  • If you have done maintenance, check all the connections you made are good
If you need further help with this, there a good section in the service manual that gives a sequence of areas to test to pin down the fault. Get a manual from http://www.TheServiceManualShop.com
Posted on Oct 13, 2007
SOURCE: error code E2813
This means that your canon printer has had a ink discharge and is covered up and there is ink laying on the sensor, The sensor if it has went out is 20 bucks you can find at a canon parts retailer
Posted on Jan 25, 2008
exil0r
  • 118 Answers
SOURCE: clear the Carriage Motor Counter epson stylus pro 4800
look for that here
Posted on Mar 26, 2009
SOURCE: Carriage Jam error with HP C6280 All-In-One
I have tiis problem; the drive belt that moves the carriage came off.
Posted on Oct 11, 2009
SOURCE: need master reset code. have carriage error
went to hp site, searched for the message " carriage error ", watched the help video , and cleared the piece of paper that was stuck behind the carriage.
any way if there is master reset code for my printer I would like to have it just in case.
Thank you .
Regards.
Posted on Oct 23, 2009
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
What do I do when I appear self-examination SEN: CR ORIGIN OFF
It means "Carriage motor encoder check error". You have to make sure that the Timing strip is centered in the carriage encoder sensors. Do not touch the strip. you have to adjust with the white levers on both sides right and the left until the strip is centered in the sensors.
Mar 22, 2013 | Epson Stylus Office Equipment & Supplies
CR motor encoder check error
CR Motor is DC motor with brushes for driving the carriage. Controlled by CR linear encoder and CR linear encoder sensor. So, check the encoder. It may be dirty or some lines missing. If the encoder OK, other possibility is the sensor.
Jan 28, 2013 | Epson Stylus Pro 7600 InkJet Printer
I am Eric, I have this error message on my epson stylus pro 9600, SERVICE REQ. 00010004
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 24, 2011 | Epson Stylus Pro 9600 InkJet Printer
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
Jan 06, 2009 | Epson Stylus Pro 4800 InkJet Printer
Hey All
Oct 13, 2007 | Office Equipment & Supplies
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
