Question about Proform 650 Crosstrainer Treadmill
I have a Pro-form 650 Cardio CrossTrainer. All of the information on the display is displayed correctly but the resistance seems to be too high on level 1 and the resistance knob is difficult to turn once turning it to level 5 and anything above level 10 will turn back to level 10 once the resistance knob is released. How do I fix this?
    Master:
  • Proform Master
  • 165 Answers
Normailly there are 2 system:
1) Manual, see the belt if there are defective,try to put a Little LUBE it,since has a LOT of mechanical stress. Replace it if Necessary.
2) The small motor in the system, can be faulty or broken, replace it.However test the batteries if the system have, clean the contacts batterys, with special liquid clean contacts cleaner, and tight very well the connector, and clean too.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Posted on Nov 03, 2017
5 Suggested Answers
SOURCE:
maxtreadmill
  • 832 Answers
SOURCE: Just bought my Proform 490 LE elliptical 1 day ago
If you purchase from a store I would take it back and exchange it, or if you purchased it on line then the manufaturer and have send somebody out to take care of this situation you have a warraty on the unit
Posted on Mar 13, 2010
  • 3 Answers
SOURCE: Have purchased a used Pro Form 900 Cardio Cross Trainer
If you can hear the adjustment motor running the problem could be related to two things:
1. Broken or stretched resistance adjustment cable.
2. Broken bracket for the magnet return spring.
If the resistance is on maximum all the time the second issue is most likely the cause.
Posted on Jun 19, 2010
maxtreadmill
  • 832 Answers
SOURCE: Pro-Form Crosstrainer XP 580 Board Failure?
Their is a sensor within the incline motor casing that may not be functioning thus causing the motor to repeat the cycle. You will most likely need to replace the incline motor.
Posted on Jul 19, 2010
Testimonial: "Max was spot on - I ordered a replacement incline motor and replaced it this morning. Our treadmill is working great again. Thanks, Max!"
  • 3 Answers
SOURCE: My Pro-Form 490 LE has
Open the rear part where the "guts" are. The magnet will be stuck against the wheel that turns when you pedal because the cable that the resistance motor pulls to remove the tension will have too much slack in it. The cable probably came off of the pulley wheel that is used to providing the necessary tension to pull the magnet off of the wheel.
To get the case off, simply unhook the right side pedal, remove the 4 bolts holding on the crank thing to remove it, then using a philips head screwdriver, remove the screws in the screw holes on the case cover. Be sure to remove the one screw on the other side near the front in order to allow the front part to "unsnap".
Posted on Jul 14, 2011
What is the power source for the display console of a proform 650 cardio crosstrainer elliptical? The display on mine is not on.
you must see the schematic diagram coming with your treadmill, or read your owner manual, and follow the instruction in section assembly or parts manual
God bless you
Nov 01, 2013 | Proform 650 Crosstrainer Treadmill
What is ''Cardio Trainer'?
Using the Cardio Trainer application for your smartphone, you can map your run, hike, bike, or walk in real-time. This free application uses GPS to map your coordinates and speed, and you can upload this information to your Facebook page by installing the Cardio Trainer Facebook app. The instantly available information, easy tracking, and ability to set time and distance goals means that you can challenge yourself to go further and faster, and share your successes with your friends on Facebook.
Sep 20, 2010 | Facebook Apps
The magnetic resistence level seems to be the same
This unit incorporates an adjusting motor for the magnetic boot. This unit also uses batteries for the upper console functions I would check the batteries first and replace them, if you haven't done so before.
If this does not resolve the problem then it could be the adjusting motor, then you will have to pull the the side panels in order to apply a 6v dc to the motor and see if it moves smoothly, if not then replace motor.
Jun 26, 2010 | Proform Exercise & Fitness
Pro form 450 cx keeps blowing fuse in plug top
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Jun 10, 2010 | Proform 650 Crosstrainer Treadmill
Dec 31, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
Proform 650 Crosstrainer Treadmill Logo
196 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Android Man
Android Man
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
