SOURCE: diagram bypass heater cord on 2001 ford expedition eddie bauer
the heater bypass is quite simple, if you look at the firewall you will see two medium sized coolant lines, remove them from the firewall and link them together using a proper sized tube, you can purchase a kit at a parts store quite cheaply
SOURCE: Oxygen Sensor Location 2001 Ford Expedition Eddie Bauer
There are four o2 sensors on this truck. one on each side just below the exhaust manifold, and one on each side behind the second catalytic converters. (just about even with the back of the front doors.
SOURCE: location of air conditioner low pressure valve
The low pressure valve on the 01 expedition is located on the accumulator on the passenger side fire wall. The accumulator is underneath the battery relay and a grouping of wires. Had to squeeze hand underneath a heater hose and an a/c line to remove cap and hook up hose. Nothing has to be removed to locate the valve just a little touchy feely. Valve faces a 45 forward toward the engine.
SOURCE: Location of Shift Solenoid in 1999 Ford Expedition Eddie Bauer?
They are round "cans" with wires attached. You should have SSA, SSB, SSC, Torque converter and Pressure Control solenoids. They control pressures and have no mechanical linkage.
SOURCE: how to replace the spark plugs on a 1997 ford
remove the coil from each cylinder,remove sparkplug,reinstall coil and wire.
