Question about Kitchen Ranges
Model QYO804A. 208 voltage 1/0 when machine turns on in ice mode, hot gas seliniod energizies,dump valve opens, pump comes on then all of a sudden machine stops and starts all over again. Until you shut machine off. This will sometimes even make it to start compressor but shut off and start from step 1all over again. We tried a new board no luck. I'm gonna try the switch I guess next. What do you all think?
fridgetech
  • 473 Answers
SOURCE: Gas range (oven)won't lite (gas broiler works fine)
Sounds like an ignitor problem or possibly a dirty orifice. Model #'s are usually on the frame behind the bottom drawer.
Posted on Oct 05, 2007
  • 833 Answers
SOURCE: GE XL44 Oven - On/Off heating of bottom burner.
Mag...not sure here. Is there a particular reason that you're suspecting a problem? Does the unit heat much slower than before? Does it bake properly? You may be looking for problems that aren't.
Posted on Dec 13, 2007
22yooper
  • 828 Answers
SOURCE: Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Posted on May 31, 2008
  • 42 Answers
SOURCE: gas valve or ignitor
the problem 99% of the time is the ignitor. even though its glowing its not pulling enough amps to open the bi-metal in the gas valve. id replace both ignitors if yours has two
Posted on Dec 22, 2008
  • 6 Answers
SOURCE: Goodman GMP075-3 ignition problem
bad board,i have had several board failures on goodman
Posted on Dec 31, 2008
Which error e1 of hoshizaki ice maker fm-170ake
E1, means low ice production
Ice machine cycle takes to long to call for a harvest. When this happens it should shut the whole unit down and then show the error code. Reset power supply, Turn off then Turn on the machine. Check for these problems. Gas leaking by the hot gas valve when in freeze mode, this valve should only let hot gas by when it is in a harvest mode. Check water control valve to make sure it is not letting water in during freeze cycle. Check water float switch to make sure it is not stuck calling for water during freeze cycle. Also make sure the machine is not in a hot location, the hotter the ambient surrounding air entering the condenser coil the longer it takes to make ice.
Mar 20, 2015 | Kitchen Appliances - Others
Why my scotsman ice machine goes off on the refridgertion light
This could be several things. This means it has tried to harvest the ice 3 consecutive times before the machine has locked out.
1. Likely Cause, Ice bridge thickness too small, not enough ice to open curtain. PROBABLE SOLUTION, Check and adjust if needed.
2. LIKELY CAUSE, ice bridge too large, ice frozen to evaporator frame. PROBABLE SOLUTION, Check and adjust if needed.
3. LIKELY CAUSE, Purge valve does not open, water melts ice bridge, not enough ice to open curtain. PROBABLE SOLUTION, Check purge valve during harvest.
4. LIKELY CAUSE, incomplete ice formation. PROBABLE SOLUTION, Check water distributor for partially plugged holes. The machine needs to be cleaned and sanitized every 6 months.
5. LIKELY CAUSE, Curtain out of position. PROBABLE SOLUTION, check curtain for swing restriction.
6. LIKELY CAUSE, Curtain switch dose not open when curtain does. PROBABLE SOLUTION, Check switch with ohmmeter if bad replace.
7. LIKELY CAUSE. Machine in very cold ambient. PROBABLE SOLUTION. Move machine to a warmer location.
8. LIKELY CAUSE. Hot gas valve does not open during harvest. PROBABLE SOLUTION. Check hot gas valve with a volt meter during harvest mode to see if you are getting correct voltage to it. If not then replace control board . IF yes and valve is not opening then replace valve.
9. LIKELY CAUSE. Harvest assist probe out of position - ejector pin not retracted. PROBABLE SOLUTION. Check harvest assist mechanism - spring should retract pin.
10. LIKELY CAUSE. Damaged evaporator. PROBABLE SOLUTION. Check evaporator surface. Make sure the plates where they intercept each other is not loose this will cause ice to hang up. check to make sure the nickel is not peeling off, if so then the plate will need to be replaced.
11. LIKELY CAUSE. Fan motor stays on during harvest. PROBABLE SOLUTION. Check controller using test mode. If this dose not help you then give me the model number so i know what machine you have.
May 28, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Not makeing ice
There could be over 50 things that will not let that machine make ice so help me out. when in freeze mode is compressor running, is condenser fan running, is water pump running, check condenser coil to make sure it's not full of dirt if so blow it out, cut machine off if water sump tray is full of water and you can still here water coming in at all check water flote to much water coming in all the time will not let water freeze. Fell evaporator plate while running if warm to touch could be hot gas valve letting hot gas in to plate in freeze cycle. you need to call a service company
Jan 08, 2014 | Scotsman Kitchen Appliances - Others
Manitowoc ice maker
sounds like your dump valve is stuck
Nov 09, 2013 | Kitchen Appliances - Others
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
Jul 18, 2013 | Scotsman HD22B-C0322MA-1B Hotel / Motel...
No ice in my ice o-matic model ice220ha1
no water entering ice forming tray
no/low gas charge
hot gas valve stuck open
no sprayer pump working or paddle wheel drive motor not working
Apr 01, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Ktm 450sxf 07 wont start
The decompression valve has come apart in the engine. Tear it down!
Mar 29, 2009 | 2008 KTM 450 SX-F
Scotsman ice machine(sce 275g)
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Dec 22, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
