Question about Singer 7462 Mechanical Sewing Machine
I am trying to wind a bobbin, have the thread loaded through all of the parts, and into the bobbin. I start winding, then all of the lights on the front start blinking and a long 3 second or so beep and it stops working all together.
    Genius:
  • 1,788 Answers
Call Singer at 1-800-4singer, Hopefully you are under warranty. That does sound like an electrical problem or board error.
Posted on Nov 04, 2010
  • detailsbyemi Nov 04, 2010
    I found another solution online that seemed to work! I pushed the reverse sewing button 3 times and it seemed to reset the machine. All is well now!
  • Mary Dunn Nov 04, 2010
    I am so happy for you. I never heard of that but I will sure remember it. I wonder why it worked, but ours is not to reason why. Good luck and happy sewing.
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
Not catching to wind the bobbin
you have to hold the loose end for a few seconds .
Mar 20, 2016 | Sewing Machines
When following manual directions to wind a bobbin, it starts out OK, but after several winds, the thread turns out with little loops on the bobbin. ??? Sylvia
Make sure that you are running the thread through the winder tension guide before it goes bobbin winder. Best to consult your owner's manual.
Also, it helps to slow down the winding process. Slower speed winds the bobbin more consistently and does not stretch the thread as much as a fast speed will.
Beginner Guide to Sewing Sewing Machine Parts Reference Guide
Nov 28, 2015 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
Tangled thread after winding new bobbin
Try winding it the opposite way you are doing it now in regards speed. If you are winding it on full speed, try winding the bobbin slower. If you are winding it slow, try faster. Also check that the thread is threading properly and is not catching somewhere, and also that the tension is correct. Finally, test with a thread that you have not experienced problems before.
Jun 30, 2015 | Sewing Machines
Bernina 135 bobbin winds unevenly
If you are finding that the bobbin is winding with more thread towards one edge of the bobbin than the other, the bobbin winder motor needs to be adjusted so that the angle of the winder shaft is properly aligned with the tension disc next to the head cover. Unfortunately, unlike many of the other models, you have to remove the covers on the Activa range to get at the adjuster. There is a spring-tensioned screw just to the left of the bobbin winder motor that adjusts the angle of the motor and therefore how it loads the bobbin. If the winder is loading the bobbin with most of the thread towards the bottom edge, the screw should be turned clockwise and if most towards the top, it should be turned anticlockise. Make adjustments until the thread is winding evenly or, at least, towards the centre of the bobbin.
If you are finding that your bobbin is being loaded somewhat randomly, make sure you are using the vertical spool holder to hold the spool and that you've got a foam pad under the thread spool. Route the thread through the thread guide before winding around the tension disc in the correct direction (see the arrow on the case) and ensure that the spool and thread do not vibrate unduly when the bobbin is being wound. If you let the spool vibrate whilst the bobbin is loading, it may result in varying tension on the thread and uneven winding onto the bobbin.
Oct 02, 2011 | Bernina Activa 130
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Singer 2517---loading bobbin?
Threading the bobbin - winding thread onto the bobbin.
Position the new empty bobbin onto the vertical bobbin rod next to the end wheel. Click the rod to the right to engage drive. Hold the outer end wheel with left hand, and rotate the inner wheel anticlockwise by about a 1/2 turn (it stops) this removes drive from the foot and needle mechanism.
(** See note below -)
From a spool of thread on the top, thread to a loop/post on the left on the top. Then back to the bobbin you want to wind. Thread through a hole from the inside-out. Hold the thread vertically above the bobbin while you depress the footswitch to start winding. Let go when it's turned a few times.
Move bobbin shaft left, and tighten end wheel after winding enough.
Fitting bobbin-
Move footplate towards you, insert bobbin in hole so that bobbin rotates anticlockwise when thread is pulled, then pull thread into the fine notch towards you. After this position thread away from you, and slide the footplate closed.
To start / load thread. Hold the end 3" of the thread through the needle behind the sewing foot. hand crank towards you to sew first stitch in air. This should retrieve the lower thread - which you can catch with a handy pair of scissors. Then pull both threads rearwards - ready to sew.
**Note -
If the threading spindle is on the top, push to the right to engage, On the earlier versions, you have to thread it through a wire hook, then down and around a plate with two slots near the bottom right, before winding around the bobbin which is held horizontally as a direct drive off the handwheel.
Hope this helps - If so rate as Fixya!
Otherwise we'll try again for you.
Thanks for using Fixya!
Jun 13, 2008 | Sewing Machines
Fitting bobbin-
Jun 11, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
181 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
