Question about Canon PIXMA MP130 All-In-One InkJet Printer
How do you change an MP130 canon ink absorber
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit......Done.
I hope this help!
Posted on Jan 16, 2015
  • Canon Master
  • 7,733 Answers
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Waste Ink Absorber on Pixma MP130 multifunctional is almost full.
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Reset canon mp190
1. Start Printer
Nov 11, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Waste ink absorber canon mp130
Hi. It happens when there is some problem with the cartridges tank, either full or not seated properly. I found that Canon recommends following methods (directly from canon) to fix it.
Method 1:
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Method 2:
Ink Absorber Replacement Options
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to release the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
* Obtain Support by Email
* For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. EST, excluding holidays).
* There will be a pay for support charge if your product is out of warranty (see next section, below).
* Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
* Technical Support is available for Customers in Canada at 1-800-OK-CANON
If your printer is no longer under warranty :
* For technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. The charge will be $9.99. If it is determined that the problem you are experiencing is due to a failure of the printer's hardware, the pay for support charge will be canceled. If your out of warranty printer is determined to have a hardware problem, you have the option to purchase, at discounted pricing and free next business day shipping , a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, and a limited manufacturer?s warranty.
Aug 01, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Wate ink absorber is full on canon pixma mp130. i have no manual
There is no replacement absorber for your machine. During warranty Canon would replace the whole printer, after warranty, you toss it and buy a new printer.
Jul 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
My printer is canon ip1980." ink absorber is almost full
My inkjet printer no. IP1980 is ink absorber is full. Please help me.
Jun 24, 2009 | Canon PIXMA MP130 All-In-One InkJet...
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ink absorber problem
Find the similar type and follow this instructions.
Mar 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
187 people viewed this question
Clive
Clive
old marine
old marine
