Question about Kenmore Washing Machines
Front loader kenmore. randomly leaves black to brown marks on white clothes/items. not rust colored. cleaned rubber gasket/seal and wiped out tub but still doing it.
  • 618 Answers
May be pinching on the door boot.
Posted on Nov 04, 2010
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
I have a Whirlpool front loading duet washer. It's probably around 10 years old... Not sure. But it leaves marks on my light colored clothes and has from early on. I just didn't realize the problem was the...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When we run the wash, black marks appear on some clothes. No pens or foreign objects are in the washer.
It can either be the rubber seal around the washer door or the bearings (normally sealed) for the tub may be leaking and getting grease into the tub. I think usually the bearing grease is brown in color. For some reason, as the rubber seals deteriorate, they tend to mark up clothes. At least that has been my experience. You may try wiping them down with some sort of cleaner (fantastic, greased lightening, etc) and see if that helps any.
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Brown streaks of clothing from dryer
Check your front and rear felt seals. How old is the dryer and what is the model number?
Eric
May 16, 2009 | Whirlpool LER4634J Electric Dryer
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Black stains on white table cloth
Hi! topjdog
I hope you have been running the monthly cleaning cycle. This includes cleaning the front gasket.
InMrFixIt
Aug 16, 2008 | Kenmore Elite HE4 Electric Dryer
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Fridgidaire Front Load Washer
This is usually an indication that the rear tub bearing is starting to go bad. The bearing is located in the rear shell of the wash tub and cannot be replaced. In order to repair, you would have to replace the entire rear shell because the bearing is actually molded into the plastic. This is common with front loader washing machines. Another possibility could be items getting caught in the rubber door boot and leaving rubber marks. However, normally this will be associated with a leak somewhere. Inspect the entire door boot and clean in behind the rubber. Inspect for any rips, tears, or places where clothes can get caught. I have experienced clothing getting snagged and actually pulling the door boot off. If the marks continue to show up on your clothes (they may even turn a brownish color) I would look into an estimate on how much it would cost to have the tub bearing replaced. It is not an easy repair, and it is not cheap. The cost usually runs around $500. I hope this helps.
Aug 08, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
138 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
