Question about Canon DC220 DVD Camcorder
Menu joystick and buttons not working
Menu joystick and buttons are not working anymore in my camera.
I tried resetting, but doesn't work.
I tried with and without a disc inside, nothing.
Could somebody help me on this issue.
Thanks.
Rogelio
  • 3 more comments
  • rba1204 Jun 13, 2008
    It's the same thing, joystick and buttons doesn't work
  • rba1204 Jun 16, 2008
    Dear Bubbabear64,
    Could be buttons or joystick problem?? or something more serious like an electronic board with problem??
    Thanks for your support.
    rba1204
  • Anonymous Nov 27, 2008
    Same thing. The joystick will move up and down, but not sideways to finalize, digitize, or whatever.
    Rick
  • rba1204 Dec 01, 2008
    Dear all,
    After send to Service, i got a quotation equivalent to a new camera for to replace motherboard.
    I decided to open it carefully and i found a flat connector between motherboard and display out of place, i fixed and re assembly and my gadget is working again !!! ; )
    rba1204
  • Tim Babcock
    Tim Babcock May 11, 2010
    What happens when you plug this into an electrical outlet?
  • Canon Master
  • 2,794 Answers
It needs to be looked at by a technician. If it isn't working when it is plugged in there is something going on with the controls.
Posted on Jun 13, 2008
  • Tim Babcock
    Tim Babcock Dec 02, 2008
    Thats good news. I'm glad it was the cable being unplugged and not a short in the wiring from it being opened and closed which is usually the case. I bet the camera technician never bothered to look at it to find the problem
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
Menu button doesn't work on kodak easyshare dx4530
Perform a power resetting and check the operation.
Jun 23, 2012 | Kodak EasyShare DX4530 Digital Camera
My toggle button does not work anymore. I can't perform any functions regarding my menu or to review photos.
Hello, You have joined the ranks of thousands of Kodak owners with the dreaded joystick failure. There is no cheap repair for this and is the down fall of these models, they sell on E-bay for parts only all the time. Sorry for the bad news, I work on these as a hobby and know their faults.
Best Regards, Russell
Dec 16, 2010 | Kodak EasyShare DX7590 Digital Camera
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
My joystick only work up down and right
I had the same problem. I took my Z760 apart and put in a joystick from a used Z760. But the problem is that the joystick comes unglued from the small computer board. Take it apart and put a tiny drop of superglue on the joystick. Use a magnifier to line up the two little tabs in the proper holes. It should work fine.
Jul 10, 2008 | Kodak EasyShare Z760 Digital Camera
Internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
Kodak easy share self-timer
You use the the self timer as follows:
(1) Push the Menu button on back of camera
(2) Scroll through the Menu items using the small joystick located in the center of your circular selector switch, until you highlight the self timer ON/OFF area
(3) Push the small joystick straight in, like a button
(4) Use the joystick to highlight the on position
(5) Push the joystick button
(6) & just snap the picture as usual.
You will have to use the viewfinder instead of the screen to point the camera.
Hope this helps
Ron
Dec 25, 2007 | Kodak EasyShare DX7440 Digital Camera
Suddenly it doesn`t focus
try resetting your camera. In record mode press menu. go to setup tab go up to reset press right arrow highlight reset press set. If that doesn't work Call the repairs center at 800-706-2534 and then keep choosing option 1. Tell them what's going on and that you would like to send it in for repairs. If they ask just lie and tell them you already talked to tech support. LOL
Oct 10, 2006 | Casio Exilim EX-S600 Digital Camera
Canon DC220 DVD Camcorder Logo
107 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
