Question about RCA Televison & Video
I have a RCA 33MS91A when I press the on switch the red led light just just flickers on off and nothing else happens
  • RCA Master
  • 17,130 Answers
Possible that the processor controller is cutting OFF the main +B power to the main board due to some errors in the board. It will be important to trace the +B voltage to the driver units, wil need to use a multimeter to check for short in the board. If so, disconnected, desolder and test with the power switched on.
Possible driver outputs, transformer , capacitor or IC can be short. Confirm and replace.
Posted on Nov 04, 2010
Hp pavilion laptop beats saudio not switched on.On pressing on/off switched led flicker 3times nothing happen?Plese advised
no pc stated, it has a model, like DV6-12345
full names only work.
no OS stated, HP has laptops from 1982 to now.
what OS, operating system is this.
XP, Vista, W7 to 10? what?
May 09, 2017 | HP Computers & Internet
How can I fix flickering & blank screen issues on an RCA 39 Direct LED HDTV Model: RLDED3955A-D ?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 04, 2016 | RCA Televison & Video
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
I need to kno how to program my 8 in 1 jumbo remote to my rca tv
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
RCA codes: 000,003,004,005, 007,009,011, 015,048,082,092, 094,096,098, 101,102,103,107, 113,125,129, 167,179,187,188, 191,194
1. Press and hold down the CODE SEARCH button •for at least 3 seconds until the red LED lights up solid red.
2. Press the device button , e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
3. Press each of the number buttons 0-9 until the LED blinks once. This will signify the 1st number in the 3-digit code for the device that is programmed in your remote control.
4. Repeat same process to find the 2nd and 3rd digit for the 3-digit code.
5. Once you have found the 3rd digit the LED will turn off.
Aug 14, 2011 | Televison & Video
The orange charge light comes on but when I press to start computor nothing happens no green light, the orange light flickers a few times.....I have taken out hard drive and batteries afew time but nothing...
Charger faulty or Motherboard problem.
You can check the power supply of the charger by measuring the DC voltage at the DC jack with a multimeter set to DC volts (red probe on the inner of the jack, black probe on the outer of the jack, should measure 18-20 volts.
Also check the security of the jack in the DC port, make sure it is not loose
See if the Ac adaptor has a green led on it, flashing LED indicates power not being "used " by the laptop
Gut instinct with this being a compaq is that the fault lies in the motherboard
Jan 12, 2011 | Compaq Evo N610C Notebook
Need a code to program an innovage jumbo remote to an RCA tv. nothing fancy just the tv code please
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 09, 2009 | Innovage Jumbo Remote Control
I have a RCA 33MS91A type 63MCC17AU television, and im unable to fine the function to tune the TV for free to air. Is there anyway I can obtain a manual for this TV?
figured it out :P Press menu , then while exit is highlighted hold menu for a few seconds to enter the installation setup menu
Sep 15, 2009 | RCA R52WH73 Projection Television
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV doesn't start up
where the light flickers at , on the remote
Feb 21, 2009 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
