Dell 20 inch lcd monitor 2007WFP
I accidentally plugged a class 2 transformer, 6v (to power speakers) into the back of my monitor (Dell 2007WFP widescreen), where it said speaker power. Well I only plugged the round part into the monitor, I did NOT plug the ac adapter into the wall socket, but after a few seconds the monitor started to flicker and it went out. Now the whole monitor, green light, display everything will not work. I now realize the monitor was outputing 12v dc for speakers not needing the external power like I thought and was giving it. The class 2 transformer was warm and i unplugged it but the damage is done. My question is how do I get this fixed? I took the monitor apart to look at the circuit boards and see if i could find a burnt component but no luck. The fuses seem ok on the PCB. What can I do? Can Best Buy fix this type of problem??
  • 4,472 Answers
Yes, If you have it sent in for repair they may be able to do it. Geek Squad would not be able to do it in the store. Although in most cases it is more costly then a new monitor. If it is still under warranty I would try and do it that way.
Good luck,
Lee
Posted on Jun 13, 2008
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
Dead
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Oct 08, 2010 | Dell UltraSharp 2007WFP Monitor
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
HOW CAN I FIT THE SPEAKERS?
1. Speakers working volteage 6V , 9V, 12V. you do onething give me the 5V ,from system SMPS ( black & red colour wires ) you should maintain the polarites. black wire is negative, red wire is positive.its working fine , then give me the 12V from SMPS. ( black & yellow wires )
if u dont maind u have any electronics knowledge. otherwise u should used adopter. there is any problem please give me the mail
Oct 12, 2008 | Dell UltraScan P990 19" CRT Monitor
Dell 20" monitor doesn't power up
I suspect Best Buy will most likely replace the monitor's entire power circuit. It's possible that you shorted out a fuse, the input transformer, or some other component in the monitor's power supply. The only way to tell for sure is to disassemble the monitor and check the circuitry visually and with a meter. This job is best left to a qualified technician.
Jun 13, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
851 people viewed this question
David Payne
David Payne
