Hello, I`m having a problem with my hp laptop which is running xp professional, when selecting run on startup menu and entering cmd into the selected space, it comes up with the error message(cmd is not a valid win32 application). I can get around this error meesage by entering COMMAND. but once in their i can not ping any think error message (C:\WINDOWS\system32\ping.com is not a valid application) any help on this would be great.
  • 13,433 Answers
You may have corrupted files, but its not supposed to be ping.com just ping or ping.exe
try ping www.google.com for example, or ping.exe.
Posted on Jun 13, 2008
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
I installed Windows XP a second time on my hard drive hence I now have a menu on boot up where I select which operating system I wish to use. I have since delted the second install of XP but the menu...
If you just formatted the partition with the second XP installation on there, it should remove the boot menu where you choose which installation to go to.
Here are a few options for you to choose from.
  • Option One: Open Start-Run and enter msconfig Click the tab "BOOT.INI" The contents of the boot.ini file are shown and a number of configuration settings are available. Under Operating systems, delete the one you don't want. Be careful not to delete the wrong one.
  • Option Two: Right-click on "My Computer" and choose "Properties" from the context menu. The System Properties dialog box will open. In the section "Startup and Recovery" click the button "Settings". To delete the unwanted operating system from the boot display menu, use the "Edit" button on the right of the entry.
  • Option Three: If the OS is Windows XP Professional, it has a command line utility for manipulating boot.ini called bootcfg.exe.
    Click start, type CMD, click OK and you are presented with the command prompt. Type bootcfg /? It will list the description and parameter list. Once again, you can delete the unwanted OS.
  • Option Four: Boot to the XP install disk and open up the command prompt utility of the disk. Enter "fixmbr" and press enter. Restart the computer and remove the disk.
Mar 05, 2011 | Microsoft Windows XP Home Edition English...
How i can download afree cmd.exe
cmd.exe, also known as the command prompt, is the command-line interpreter on Windows PCs. You do not need to download it it is already a part of Win XP.
All you need to do is click on Start, select Run and in the dialog box that opens type "cmd" and press Enter. A command prompt window will open.
Jan 10, 2011 | Microsoft Windows XP Professional
When I turn on my computer the default internet browser automaticaly run. Please sent me solution.
Hello, please go to start type in run in the search box and press enter,it will bring a dialog box. In that dialog box, type in cmd and press enter. you will see a command prompt, type in msconfig and press enter go to startup menu and disable the internet browser from automatically running when you start your system. click on ok or save the changes that is it!!! regards
Dec 01, 2010 | Computers & Internet
I dont know my password
If your using windows xp, reboot the computer and press f8 as it boots, enter safe mode, select run from the start menu and type in "control userpasswords2". From there you can change the password. If you are using windows 7 or vista, enter safe mode with f8 after turning the computer on, open the command prompt (cmd/cmd.exe) and type in "control userpasswords2".
Oct 02, 2010 | Computers & Internet
I am now not able to run Defragmenting tool and also not able to down load Microsoft security essential?
ok i am making a lot of assumptions here, you didnt tell us your operating system, but can i guess your running norton antivirus. close it if you are. remember some antivirus's have a defrag in them this may be interrupting the process. let me know
mel
Jun 11, 2010 | Microsoft Windows XP Professional
I need to find my ip address cant find it can u please help me i have acer aspire 5050
go to the RUN command on the start menu
Type CMD then ENTER
a box will appear
In that box type IPCONFIG /ALL
your IP will be listed in there
Oct 12, 2009 | Acer Aspire 5050-3242 Notebook
Zero wireless configuration has been disabled on presario
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
Jul 29, 2009 | HP Computers & Internet
Windows xp shutdown after entering ipconfig, cmd on start-run...
could be a virus
do a system restore if possible to before the issue stated, then run a virus scan (maybe run an online scan in case your installed antivirus has been infected) something like housecall.trendmicro.com
If you cannot do a system restore in full windows, try it in safe mode (tap F8 during boot, select safe mode)
Jan 31, 2009 | Microsoft Windows XP Professional
HOW DO I GET INTO MS-DOS PROMT
  1. Click Start.
  2. Click Run.
  3. Type cmd or command and press enter.
Jan 18, 2009 | Compaq Presario C700T Notebook
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
