Question about Amana DLE330RAW Electric Dryer
Dryer is not spinning on a full load not even on a medium load
  • Amana Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 04, 2010
I have a gleh1642fs4 model that drum will not spin?
I have a GLEH16242 Frigidaire/Electrolux stacking washer/dryer. The main bearing went out on the washer. I did the expensive fix of replacing the outer drum/bearing assembly in hope of nothing going wrong. Everything went together well, but now it won't go into high speed spin. It does if I have no clothes in it, but as soon as I introduce clothes it only does the 'medium spin' but never advances to the high. I've changed shocks, confirmed the door switch is working properly and double checked level. Even placed it on a big thick sheet of plywood in hops of stabilizing it more. It does have a wobble to it when it starts spinning, but when it kicks into medium spin, is smooths out.
Oct 11, 2013 | Frigidaire GLEH1642DS Front Load Stacked...
Spin problem
it seems like your brushes need replaceing or your moter is on its way out
Oct 17, 2012 | Washing Machines
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Maytag dryer model number lde7334ace wont spin a full load of clothes we put a new belt on and fan blade now it wont spin a full load
recheck the belt, Tim:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 06, 2011 | Dryers
I have a Frigidaire GLEQ2152ES 5.8 cu front-loading dryer. For the past year I have had no problems. Today I went to put in the first load and when I tried to start it I got nothing but 3 beeps. Even...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 29, 2010 | Frigidaire Dryers
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum spins without a load but won't witha load
It sounds like a motor problem. It puts the motor under maximum load, when dryer is full and just trying to begin to spin.
There are 2 different types of motors, those with capacitor start and those with inbuilt centrifugal switch.
What is your make and model of dryer please? Or if you take off the back panel, can you see a small plastic cylinder, about 2 inches long, with 2 wires to it? Will be mounted close to the motor, but seperate from it.
If it has one, try replacing the capacitor. ( I have about half dozen good secondhand ones lying around at my place (Brisbane))
Good luck, let me know how it goes.
May 06, 2009 | Dryers
Washer won't spin if large load
There is a sensor and if the weight of the load is to great it will not go into spin cycle
Jan 08, 2018 | Kenmore 98702 Stacked Washer/Dryer
Amana DLE330RAW Electric Dryer Logo
43 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
