Question about Samsung 50 in. Plasma TV
There is a burning smell coming from the left side (from the back view) which I think is the sustain board. A repair man said the TV isn't working. Because of the P Y board, is that the same thing? When I wouldn't pay the $520 he wanted to fix it, he wouldn't help me. The tv has sound but no picture. Model number PN50A-450p1D. Thank you!
  • 129 Answers
If is coming from the left side is the backlight inverters. Is the longest board on the TV if is got two one is the master and the other is the slave. check for any burned marks. $520 is redicules.
Thanks,
Posted on Nov 04, 2010
Plasma comes on but picture is bad looks like shinny bits on peoples faces did
Sounds like Your Y SUS and Y upper Y Lower boards are on their way out. Unplug the TV completely for a few hours then remove the back panel look for the Y Sustain board It will be printed on the board next to the Boards Rev number (part number). it it's usually (open back view) In the Middle towards the left side and the Y upper.Lower are the 2 boards on the left hand side. The PSB power supply board is in the middle and next to the PSB on the Right is the X-main. shop jimmy partsstore and ebay for refurbed boards. Or you can pull the boards by removing wire harness ribbon cables and a few screws and take it for a bench test at an electronics/pc repair shop. It's usually not the entire board but a faulty component on them. Mainly the transistors.
Mar 06, 2014 | Philips Televison & Video
No picture and burning smell from left side
Bad COF ic on buffer board. Can usually tell which one's bad. It will look overheated or a hole in top of ic. Look at upper and lower buffer boards to see which ic is bad. Can get from Encompas Parts, Recommended replace y sustain with buffer.
Nov 26, 2011 | SNK Magnavox 42MF231D 42 in. Plasma TV
Burning and fan type sound
That is probably the power section about to fail. The burning smell is going to be from overheating components. You will have to take it into either an akai repair depot or a local tv repair and have it looked at. Get an estimate first. The repair cost on this could be cheap if itis obvious and the repair gys are on the ball or it can be pricey if they just replace major parts (typical). Also have a good idea of what replacement cost is so you know if it is worth fixing.
Jul 20, 2010 | Akai LCT42Z6TA 42 in. LCD Television
TV went out.
U have a dead power supply board,burn componnents parts on the power supply board.Replaced the power supply board,u will get ur power back as normal function as before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 02, 2010 | Philips Magnavox 42MF521D/37 Television
Will drain most of water but will not spin and smell something burning
The motor is probably stuck and burned. Open the door and turn the drum manually. You should be able to turn it easily by hand if the motor is not stuck.
Remove the back panel and use your sense of smell to verify where the burning smell is coming from. The possible source of the smell is the motor or the motor control board located on the left side of the machine viewed from the rear.
Let us know the source of the smell for the replacement guide and for further troubleshooting if necessary.
Feb 22, 2010 | Washing Machines
My Sony plasma tv made a pop sound and now picture is dark.
You will need the y and x sustain boards replaced, possibly the buffers. very expensive repair. you can replace one board but its best to do all of them.
Jan 22, 2010 | Sony 50 in. Plasma TV
Top Half of my Philips Plasma tv is out Just the lower half works
It sound like the upper y drive board off the y sustain pcb. This board is located on the upper left side of the tv viewing from the back. Need to get part number off the board to get correct one. Philips uses differant boards for same models
Jun 26, 2009 | Televison & Video
We were watching tv and all of a sudden we heard a
I had the same problem. We replaced the Y Sustain board. It was under $200 and not at all hard to do yourself. Remove the back of the tv. Make sure you watch what screw goes where. You will see the board on the left side. The number should be on the bottom right corner of the board. Just watch how you removed the board making small notes as to what goes where. Its really not that hard and you can save 600$ or more
Jun 06, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
Samsung PS-42S5H
Since you smell it above one side of the panel I will guess the right side (from the front). This is where the Y Sustain board is located, it has large heatsinks over the drive ic's to dissapate heat. If the ic's are bad this is more than likely the smell. This board controls the scan of the picture and drives the plasma panel. I would definatly have a technician look at the unit, these are normaly econimical to repair.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung  50 in. Plasma TV Logo
253 people viewed this question
Jerry Greenberg
Jerry Greenberg
