Question about Audiovox VM9512 Car DVD Player
Jensen vm9512 -- is there a master unlock code
Hi i need to know if there is a master code to unlock the head unit in case you lose power and have forgotten your code , please advise thanks
Ok i got a hold of audiovox call center and to bypass or unlock your stereo
you have to type on the radios password (very begging) blue screen
5,4,3,2,1,0 this is the factory reset for all the jesen i hope
it worked for my VM9512 !!!!!! with the lost user password
hope this helps
Posted on Sep 30, 2008
  • 959 Answers
I thought it was 0 1 2 3 4 5 , (6 digits)
Posted on Nov 18, 2008
    Problem Solver:
  • 5 Answers
    New Friend:
5,4,3,2,1,0 it worked on my vm9512!!!!!!!
Posted on Nov 07, 2013
Contact Audiovox...Also members beware the security code is a safety feature to discourage theft of the headunit so beware of people seeking this type of info.
Posted on Jul 23, 2008
2 Suggested Answers
SOURCE:
SOURCE: jensen vm9512 -- is there a master unlock code
there is a master code. it is 0, 1, 2, 3 , 4, 5
Posted on Sep 22, 2008
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
I need the pin for jensen vm9512
try one of this two codes first is 0123 if doesn't work try 0000 let us know this work.
Jul 17, 2009 | Audiovox VM9512 Car DVD Player
Master code for jensen vm9512
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 23, 2009 | Audiovox VM9512 Car DVD Player
Vm9512 touch screen stop working just like that
The backlight has gone bad. I have seen this exact problem in SEVERAL other Jensen units.. The backlight might last 5 years, or in extreme cases, maybe 15 minutes.. I have also seen them bad out of the box.
Dec 19, 2008 | Jensen VM9510 Car DVD Player
MY UNCLE WORKED FOR JENSEN FOR MANY YEARS AND HE HAS A SOFTWARE THAT CAN CRACK THE CODE OF ANY RADIO OF ANY BRAND USING THE SERIAL NUMBER OF IT, IF U LIKE POST YOUR SERIAL # AND MAYBE HE COULD HELP YOU OUT.
Aug 28, 2008 | Car Audio & Video
[email protected]
What code? Do you mean an unlock code? You'd probably have to go through the manufacturer for that. If you mean a code to allow DVD playback while moving, there isn't such a thing. To do that you have to wire it a certain way (which is easy).
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 27, 2008 | Audiovox VM9512 Car DVD Player
Jensen vm9512 unlock code for the code
setup menu click language then on the remote pres 54321 unlock the security code.
Jun 14, 2008 | Audiovox VM9512 Car DVD Player
Parking Brake Bypass
Hi
You need the remote to do the code thing, or try hooking the parkbrake sensor up to full time power to trick the unit into thinking that the parkbrake is off. Try that and see how you go. If it doesnt work that way, try taking it to full time chassis(earth)
regards
robotek
May 15, 2008 | Audiovox VM9512 Car DVD Player
Security codes
Contact Jensen and tell them you have to unhook the battery to fix the car and the deck is already in the car when you purchased it. They might make you turn it in and charge a fee. Goodluck.
Feb 15, 2008 | Audiovox VM9512 Car DVD Player
Audiovox VM9512 Car DVD Player Logo
8,433 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
