Question about Olevia LT42HVi 42 in. LCD Television
TV will not turn on. Sometimes if I unplug it and then plug it back in the blue power light will come on for a few seconds.
    Problem Solver:
  • 9 Answers
Computer chip that runs these functions could be screwed up. there could be a short in the wiring inside it. check for manufacture waranty
Posted on Nov 04, 2010
Philips LCD TV Turns Off After Being Turned On
Most LCD TV power problems are simply solved by replacing the power supply board.
Oct 07, 2017 | Audio Players & Recorders
Turns itself on and off every few seconds. The blue light at the front of the TV stays on steadily during this process. Tried unplugging it but made no difference.
When you unplugged it, did you leave unplugged for quite a few hours? And in the meantime of being unplugged, did you press and hold the power button for 5 full seconds, and then wait half hour more to plug back in? If you did this and it still is the same, then you likely have either a loose wire or solder joint or your high-voltage transformer is likely bad.
Jan 23, 2010 | LG 32LH30 32 in. LCD HDTV
Blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Sep 26, 2009 | RCA L42FHD37 42 in. LCD HDTV
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
Power supply for dmtech wt20xt lcd tv
I have DMtech 20" with intergrated DVD and had the same problem- blue light lit on power switch but no response on power up.
I noticed that when the power cord was unplugged from the back of the TV the green LED on the power supply would brighten and consequently dim when plugged back in. Sometimes the blue light on the power switch would strobe very quickly but you had to look carfully for this.
I repeatedly unplugged the DIN type power plug from the back of the TV untill the green light on the power supply stayed a constant bright and there was no strobing on the blue light on the front of the TV, when I powered the TV on at this point the button worked again and the tv powered up with the silly tune then life in the screen. I did have to do this a good few times (I'm tenacious) but it did work!!!!!
Hope this helps someone else, cheers.
Apr 11, 2008 | Televison & Video
Insignia IS-LCDTV26
Just posted the answer to this to SDBudman look it up... It's a fairly easy and common problem.
Good Luck!
Bill
Mar 25, 2008 | Insignia IS-LCDTV32 32 in. Television
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
Dec 15, 2007 | Toshiba 50H81 50" Rear Projection...
Olevia LT42HVi 42 in. LCD Television Logo
233 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
