No power after turn power sw - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Posted on Nov 04, 2010
SW 2 Will not turn over
Check for power on small wire on starter when trying to start . No power ignition switch if you have power either bad starter or ground
May 22, 2014 | 1999 Saturn SW
Troubles Sony ps-b80 1)When power sw is on,red
try getting itr cleaned by a reputable repair shop may just b dirty
Oct 02, 2013 | Audio Players & Recorders
It says please turn power on the fax sw
Unplug the machine from the wall, if you can not find the switch.
May 22, 2012 | Office Equipment & Supplies
Gateway Desktop GM5626: Would not power-up, replaced Power Supply; Then Mother Board beep once when trying to turn-on; replaced Mother Board; Mother Board lights on, but when I try to turn on the CPU...
some powersuplay comes with 2 extra connectors a 4pin based switch connector and a alternate power supply for the fan...you must to be sure if it is comatible......check the model and search on google for compatibility ...
May 31, 2011 | Computers & Internet
1 -3 way sw installed with a 3 way dimmer without a load,test voltage on wires for light to make sure sw is working properly. with sw on 120V,sw off 100V?? why the voltage with sw off? All new wiring.
You will always have voltage through the black incoming wire unless you turn your circuit breaker off. This wire will be attached to the common terminal on the switch. Is this what you were testing?
The power comes in the common terminal and then is switched through, or on, and broken, or off, when the dimmer is clicked. Therefore, there is always power coming into the switch.
Hope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Mar 28, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
Intel E210882 Motherboard can't ON
> Check the power connection to your computer in good condition.
> Remove the SW on the motherboard connection and switch on the computer by using the SW pin tespen to affect positively and negatively. (To make sure the button on / off function)
If your computer can be turned on this means that the button on / off there is a problem but if the contrary, create a test on your computer power supply box in a manner which was troubleshooting with the power supply box which is still functioning properly or even better one.(Problems on the motherboard can also cause your computer can not be turned on)
If you have to do some tests and the problem is not coming from your motherboard, I believe there is no problem for your computer is switched on and used as usual.
Jul 22, 2010 | Dell (E210882) Motherboard
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
How access the service menu
On the front video input terminals there is a small hole to the left of the terminals use a small thin metal rod or paper clip to push the factory mode button.
SD-533HD5, SD-643HD5
7.1.4 The method of power-on (for service)
When removes the Front Grille, remove the
connectors from POWER SW Assy, FRONT INPUT
Assy and FRONT LED Assy and remove the Grille.
This set is not turned on the power in the state that
removed the connectors.
At this time, connect a connector that connected to
the POWER SW Assy to the SHORT Assy, and can
turn the MAIN POWER SW to ON.
Be careful there is a case to be turned on the power
in the state that front side of this set opens.
In addition, the front input and front key do not work
because each Assy does not connect it, but the
remote control unit works in the same way normally.
There is a Factory Key on the FRONT LED Assy.
When enter the Factory mode, transfer a code with
the remote control unit or connect the FRONT LED
Assy. (Turn the Main Power SW to OFF when
connects it.)
SHORT Assy
The connector of POWER SW Assy
The connector of FRONT INPUT Assy
and FRONT LED Assys
Factory Key
Nov 19, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
